safe to run without a BOV?
Old Apr 1, 2005 | 09:04 AM
See Are X's Avatar
Default safe to run without a BOV?
we're installing a Greddy turbo kit on my friends RSX TypeS. The HKS SSQ hasnt came in yet. Is it safe to drive around without a BOV??
Old Apr 1, 2005 | 09:13 AM
beepy's Avatar
Default Re: safe to run without a BOV? (See Are X)
As long as you don't see more than 5 PSI or so. The turbine can spin above 100,000 RPM at times. You don't want it to snap back at that speed.
Old Apr 1, 2005 | 09:15 AM
fjt's Avatar
fjt
Compressor surge is never your friend..even at 2-3 psi it will hurt your turbo.. I wouldnt run the car w/o the BOV.
Old Apr 1, 2005 | 09:45 AM
B18Flip's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">Compressor surge is never your friend..even at 2-3 psi it will hurt your turbo.. I wouldnt run the car w/o the BOV.</TD></TR></TABLE>
agreed...peterk was running his car w/o one at first and ended up w/ a bad turbo. Unless you stay in vac, then i think it's ok
Old Apr 1, 2005 | 09:50 AM
citrus3000psi's Avatar
If you do drive it around just when you let off the gas let off slowly.....That way the pressure in the system can be reduced slowly by the engine sucking in the air.
Old Apr 1, 2005 | 10:06 AM
RemerLex11's Avatar
Default Re: (citrus3000psi)
you can run it w/o a bov but more than 2 psi can potentially damage it so play it safe and wait till you get it.
Old Apr 1, 2005 | 10:10 AM
Evanmb44's Avatar
Default Re: (Matt5745767)
just stay in vacuum....you wouldnt want to damage your new investment would you?
Old Apr 1, 2005 | 10:12 AM
tgreaves's Avatar
Just get a cheap $30 bov from ebay.. Thats what I am running and it works perfectly..
EJ8 GSR-T
Apr 12, 2006 07:50 PM
MiKeAhOwSkI
Oct 13, 2005 06:02 PM
Hella Flush Kevin
Mar 15, 2004 03:58 PM
iluvdrt
Oct 2, 2003 11:01 PM
boosted jetta
Sep 25, 2003 04:14 PM
