is this turbo ok for b18b? 0.53 A/R and a 0.47 EXH
hey just wondering what yall think. i was reading that some found a .42/.48 to be a little small (lost maybe some power about 6500), but then again some found it to be good. and then some are saying that .48/.60 might be a little big. i want to have a large powerband 3-6900k....so this size seems to be good for 1800cc kinda in the middle of the two
Re: is this turbo ok for b18b? 0.53 A/R and a 0.47 EXH (hamburgler)
thats not too bad. a 60/48 would be fine, a 60/63 would probably be ideal.
I have a 42/48 I'm puttin on now...I have a feeling im going to be disappointed. I had a 60/63 on my old hatch and it pulled hard and made 253 hp at 9-10 psi
What turbo do you have? The A/R numbers don't tell us anything at all. Compressor wheel size and turbine size would be good if you want to know how it will work on your b18. At least the family the wheels are from...t25, t3, t4?
Re: is this turbo ok for b18b? 0.53 A/R and a 0.47 EXH (92civicb18b1)
here is the specs:
compressor-whl dia:56mm, trim:55, a/r:.53
turbine-whl dia:47mm, trim:72, a/r.47
Re: is this turbo ok for b18b? 0.53 A/R and a 0.47 EXH (Bailhatch)
As BailHatch asked -
what turbo are you even using??? t25/t28/t3-t4 ????
You can list AR all day long, but they are all relative to turbo size
PhatBoy5015
08-22-2006 11:17 AM
