Cooling ?
Old Apr 1, 2005 | 03:31 PM
str8boost's Avatar
Default Cooling ?
Running B16 wt turbo, using stock civic rad , also using pusher fan mounted on opp side... took car out the other night after boost run, temp went up past the halfway mark, shut off, havint ran since... fan runs alot , car warms up quick, should i be using a aftermarket 2 or 3 row...what do most run??
Old Apr 1, 2005 | 03:58 PM
HitEm'Up's Avatar
Default Re: Cooling ? (str8boost)
You may want to upgrade to a higher cooling rad.
94hondaccord
Apr 11, 2012 01:50 AM
b20bFourDoorCivicLX
Jan 12, 2012 09:39 PM
la_teta
Oct 5, 2010 02:49 PM
Ej1SIR
Apr 14, 2010 05:02 AM
T9U4ReBgO
Dec 5, 2007 02:52 AM
