supercharger lag???
Old Mar 30, 2005 | 05:06 PM
ZackKVtec's Avatar
Default supercharger lag???
i just put a JRSC on my 96 gsr and i feels as if the supercharger bogs at low rpms, and also that it needs to spool up like a turbo... now i think that it could be a retarded the timing too much (a conservative 6 deg btdc) or maybe im running too rich or lean??? if anyone else has a jrsc B18C1 i would really appreciate any information.. thanks alot
Old Mar 30, 2005 | 05:11 PM
supercharged98's Avatar
Default Re: supercharger lag??? (ZackKVtec)
you're bogging down because you're prolly running too rich. I had the same problem and had to cut the fuel and retard the timing a bit and it helped out a lot. If you dont have the map controller...i'd highly recommend it. Also, the supercharger doesnt have lag..but from my experience with my supercharger..it takes a few seconds to hit full boost. hope that helps at all.
make sure you're using good octane fuel...my sc never ran right unless i used 92 or up octane
Old Mar 30, 2005 | 05:25 PM
keebler65's Avatar
Default Re: supercharger lag??? (supercharged98)
timing can play a large role as well as fueling. if you're retarding it at the distributor, then it's obviously much more retarded than it needs to be when it is low boost (low rpm). you're better off with a "standalone" system such as hondata or uberdata. this will allow you to specify how much timing to retard at a given boost level. also, it will allow you to tweak your fuel map(s) for optimal performance. a well tuned JRSC setup should have ZERO "lag".
Old Mar 30, 2005 | 05:26 PM
frago's Avatar
You can't just bolt on a forced induction piece and expect it to be perfect. Tuning would be the key here.
Old Mar 30, 2005 | 05:29 PM
ZackKVtec's Avatar
Default Re: (frago)
yep, that would be it, just making sure i wasnt imagining things.... thanks for the responses guys
Old Mar 30, 2005 | 05:33 PM
frago's Avatar
Hey, good luck and keep us posted on how you make out.
Old Mar 30, 2005 | 05:34 PM
ZackKVtec's Avatar
Default Re: (frago)
one more question, would a piggyback like Greddy e-manage be able to map out and tune all the **** as well as a hondata or uberdata setup?
Old Mar 30, 2005 | 06:11 PM
95GSRTT
Guest
Posts: n/a
Default Re: (ZackKVtec)
no hondata will be alot better than emanage. You could try neptune also.
Old Mar 30, 2005 | 06:35 PM
keebler65's Avatar
Default Re: (95GSRTT)
yeah the e-manage would not run it as well as a tuned AEM/hondata/uberdata/neptune system would.
E-gg's
Nov 14, 2005 06:49 AM
ZackKVtec
Mar 31, 2005 05:36 AM
2K Teggy
Nov 4, 2003 04:02 PM
MartyMarGSR
Apr 2, 2003 07:35 AM
B_1_8_hatch
Apr 1, 2003 06:09 PM
