oil temp guage???
Old Apr 1, 2005 | 11:26 AM
vangc6780's Avatar
Default oil temp guage???
do i really need this guage or not???
as of right now i have oil pres., egt temp and boost gauge.....
well i ever run hard enough for the oil to get extremely hot???
Old Apr 1, 2005 | 11:37 AM
vangc6780's Avatar
Default Re: oil temp guage??? (vangc6780)
any1???
Old Apr 1, 2005 | 12:10 PM
TurboB18C1's Avatar
you can run one but it is not required, it is only important when you are running a road race setup and you have to moniter oil temp. Oil is always close to your coolant temp since coolant flows through out the block and is cooling the oil as well. i dont know anything about your setup but if your boosting above 25psi and run your motor around redline alot i would tell you to get a guage but in any other case i would not.
Old Apr 1, 2005 | 01:42 PM
vangc6780's Avatar
Default Re: oil temp guage??? (TurboB18C1)
thanks alot!!!
ohsnapzafingcu
Jul 6, 2009 06:48 AM
Andrew Sutherland
Jul 12, 2008 04:37 AM
realis9
May 23, 2006 08:55 PM
MattD@Stoptech
14
Aug 6, 2002 10:46 AM
