Apex I AVC-R questions
Ok, I had the avcr installed in my 94 turbo lude. The oil light kinda comes on adn off at times. The oil level is fine, no leaks or anything. Also, I need help on reading some of the numbers and different lingo. Like i want to set my low boost at 6-7 and the high at 10. How do i do this? I tried to do the self learn and didnt work out for me. Also try to do the gears learning and didnt work
Re: Apex I AVC-R questions (kleefton)
as far as the oil light, have you done any work to it latly. I know sometimes the connector seems like its in place when its not, so you may just have to give an entra push on the connector.
Re: (drumking15)
First off what size wastegate spring are you running? That will be your OFF setting on the AVC-R.
To setup for 6-7 psi(if your wastegate spring is lower then this). You will need to goto setting A. Set the boost level to what you want(.4-.5 BAR). Then start low on the duty cycle. I would say around 40% or so. Then slowly go up until you reach close to the boost level you want. It will go into self learning mode and change the duty cycle % by RPM to keep a steady boost level. Do the same for the B setting set the boost level to .7 BAR(10.25 psi) and star the duty cycle at the A setting and go from there to start tuning for 10 psi.
Re: (TurboLSVtecTeg)
i have a 7 or 8 spring. i try to get the self learn mode and its not working for me. ihave the stars on the screen but dont know what else to do from there. do i leave it on the boost duty screen or do i monitor? let me know thanks all
Re: (PreludeSiTdriver)
If the wire was bad the oil light would never come on, or would sporadically "never come on". The dash oil light gets ground through the oil pressure switch/the block. Disconnect it and the light stays out.
Thanks for all the input all, it was that the wire came off the switch so I guess when i drove it would tap the connector thus making the light blinkie joo know what i say mayne. Well, yes I fixed it thanks all
