How close is the downpipe allowed to be?
Old Mar 31, 2005 | 07:52 PM
GForceInteg's Avatar
Default How close is the downpipe allowed to be?
I cant move it any lower?? I have an oil cooler think this will be an issue?
Old Mar 31, 2005 | 07:59 PM
Blaze45's Avatar
Brrraaaap!
Default Re: How close is the downpipe allowed to be? (GForceInteg)
I dont think that it will be an issue at all, you could always heat wrap the exh. if you are that worried about it.
Happy Boosting,
Blaze
Old Mar 31, 2005 | 08:07 PM
99blusi's Avatar
Default Re: How close is the downpipe allowed to be? (Blaze45)
I don't see it being too big of a problem...
Old Mar 31, 2005 | 08:44 PM
SSBPGSR's Avatar
you should be fine, just try to avoid those massive speed bumps
Old Mar 31, 2005 | 09:40 PM
Def's Avatar
Def
Put heat reflective tape on the oil pan and you're good to go. That and oil temps are low as hell on the street compared to what's safe. I have to flog my car to get it up to ~170*F on the street, and at the track I'm at 240*F after a few laps and that's still considered "fine" for synthetic oil(I use Mobil1). You just can't generate near the heat needed to break down the oil on the street, even if you think you're driving like a maniac.
Old Apr 1, 2005 | 04:17 AM
CRVRX's Avatar
Default Re: How close is the downpipe allowed to be? (Def)
I think if you move it a little more to the passenger side and put the flex after the oil pan you will have more room between the Dp and the pan.
Also rotate the 3 bolt flange (like a triangle) which will give you a little more ground clearance.
Old Apr 1, 2005 | 05:34 AM
Default Re: How close is the downpipe allowed to be? (CRVRX)
alright thanks alot everyone, yeah im going to heat wrap it for a question i posted in a previous thread. Thanks again.
Old Apr 1, 2005 | 06:59 AM
citrus3000psi's Avatar
The cool thing about stainless steel is that it doesn't hold heat, so at idle its not nearly as hot as when your driving...and when your driving you have air to cool down the area. I would say your OK.
Old Apr 1, 2005 | 06:10 PM
Default Re: (citrus3000psi)
its galvanized not stainles, does this make a differance?
bjones6215
Sep 10, 2013 07:55 PM
flipstar760
12
Dec 17, 2006 05:07 PM
hondaboy4life
Sep 29, 2006 08:01 AM
ekim952522000
Dec 12, 2005 04:47 PM
DeepSi
Oct 1, 2002 04:16 PM
