is there a way to run 3 different boost settings?
Old Mar 30, 2005 | 08:12 AM
Black R's Avatar
25 Year Member
Default is there a way to run 3 different boost settings?
I know the avcr can do gear dependant boost... but how is it about spiking?
I'd like to run maybe somewhere between 2psi to 5psi on the wastegate spring.
Then a bit more for low boost setting - perhaps 7-9psi, and then 12-14psi for my high boost setting.
How can I do this?
Old Mar 30, 2005 | 08:14 AM
Dragline's Avatar
Default Re: is there a way to run 3 different boost settings? (Black R)
with the avcr.
Old Mar 30, 2005 | 08:22 AM
flip1199's Avatar
Default Re: is there a way to run 3 different boost settings? (dragline)
i "believe" the avc-r only allows 2 different boost settings. so if you can find a low enough spring then that can be your 2-5lb setting. then for the other 2 two settings, use A as you 7-9 lb setting and B as your high boost setting in the avc-r.
Old Mar 30, 2005 | 08:27 AM
underpressure02's Avatar
why would you only want to run 2-5psi?
Old Mar 30, 2005 | 08:28 AM
Black R's Avatar
25 Year Member
Default Re: is there a way to run 3 different boost settings? (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">why would you only want to run 2-5psi? </TD></TR></TABLE>
Let's just say that traction is an issue in the lower gears.....
Old Mar 30, 2005 | 08:33 AM
Bulldogg83's Avatar
Actually the AVCR has a A setting and a B setting that you can scramble back and forth on. If you set up the Gear Dependant Boost Settings then you can run whatever boost levels you want. Another way to go would be with the new Turbo XS 4 Stage Manual Boost Controller.
Old Mar 30, 2005 | 09:16 AM
turbo*s2k's Avatar
Default Re: is there a way to run 3 different boost settings? (Bulldogg83)
Electronic boost controller.
My Blitz SBC-id allows 4 boost settings.
And if you turn it off. It runs off the spring.
Old Mar 30, 2005 | 09:17 AM
Bulldogg83's Avatar
Default Re: is there a way to run 3 different boost settings? (TurboChrgd_Civic)
Another one that is a good one that I failed to mention is the Innovative.
Old Mar 30, 2005 | 09:21 AM
flip1199's Avatar
yup.. the Innovative has that feature along with gear based boost, and time based boost. Should have mine arriving today
also i beleive the turbosmart allows mulitple boost settings.
Old Mar 30, 2005 | 10:45 AM
m R g S r's Avatar
what about the turbosmart one?
I know they have some awsome features, not sure how many boost settings though....
Old Mar 30, 2005 | 11:10 AM
flip1199's Avatar
Default Re: is there a way to run 3 different boost settings? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">what about the turbosmart one?
I know they have some awsome features, not sure how many boost settings though.... </TD></TR></TABLE>
turbosmart has 3 different boost settings
Old Mar 30, 2005 | 03:40 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">Electronic boost controller.
And if you turn it off. It runs off the spring. </TD></TR></TABLE>
Old Mar 30, 2005 | 03:42 PM
SOHCmaster's Avatar
Blitz !!! Plus scramble mode
Project X
Jul 17, 2008 08:38 PM
integraRS-T
Jul 8, 2007 03:56 PM
1RS2NV
Mar 15, 2004 03:18 AM
Coldsi
May 14, 2002 01:03 PM
