JDM CTR tranny or USDM type R tranny
What do you think would be better for a 479WHP 1.6L ... well 1.7L motor???
Im thinking of switching the CTR tranny off the motor and putting my USDM type R with longer gears!
Re: JDM CTR tranny or USDM type R tranny (jdmhonda)
serious??? so JDM CTR is stronger diff then TYPE R USDM????
I have 500WHP so i need a diff that can hold!
Re: JDM CTR tranny or USDM type R tranny (ATgrills.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com »</TD></TR><TR><TD CLASS="quote">What do you think would be better for a 479WHP 1.6L ... well 1.7L motor???
Im thinking of switching the CTR tranny off the motor and putting my USDM type R with longer gears!</TD></TR></TABLE>
The CTR and USDM ITR tranny have identical gearing and final drive. They also have the same LSD.
The tranny with different gear ratios is the JDM ITR tranny.
liam
liam
Re: JDM CTR tranny or USDM type R tranny (liam821)
I really dont believe that.... im doing 3350RPM at 100KPH in 5th with my ITR and like 3500 with the CTR.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com »</TD></TR><TR><TD CLASS="quote">I really dont believe that.... im doing 3350RPM at 100KPH in 5th with my ITR and like 3500 with the CTR.....</TD></TR></TABLE>
Different tires maybe? Or maybe your tach is off.
http://www.ff-squad.com/tech/temp/Bgears.htm
According to that and every other b-series tranny specs ive seen, they are the same.
liam
liam
arent the R trannys a little short with almost 500 whp? Unless its a straight race car or something...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">usdm type r diff only holds like 250whp.</TD></TR></TABLE>
Not true.
Not true.
Re: JDM CTR tranny or USDM type R tranny (adictionbass)
these are the trannys I have right now at my garage
99 stock USDM type R
99 JDM CTR stock
94 GSR USDM stock
95 LS Stock
whats the best set up for a 500WHP car???????????????????????
thanks
99 JDM CTR stock
94 GSR USDM stock
95 LS Stock
thanks
Re: JDM CTR tranny or USDM type R tranny (TURBO4drTypeR)
I herd if you do like LS 5th you will always have to double clutch since the gear ratio is so far off!!!
is this tru??????
is this tru??????
not true..
i have one and i am pushing lil over 300whp and it is GREAT!!
not true..
i know someone that made 588whp on gsr tranny w/itr lsd
btw im using a 99 jdm itr tranny(4.78 final) i love it... shootin for 700whp give or take
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com »</TD></TR><TR><TD CLASS="quote">these are the trannys I have right now at my garage
99 JDM CTR stock
94 GSR USDM stock
95 LS Stock
thanks</TD></TR></TABLE>
i wish i had your problems and 4 spare trannys.
99 JDM CTR stock
94 GSR USDM stock
95 LS Stock
Re: JDM CTR tranny or USDM type R tranny (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">i wish i had your problems and 4 spare trannys. </TD></TR></TABLE>
^^^ ditto
^^^ ditto
typer_696
10-06-2010 11:08 PM
96GS-R-Kaden
11-13-2007 11:14 AM
