CP pistons clearance
Old Apr 1, 2005 | 05:14 PM
Civic TSI's Avatar
Default CP pistons clearance
What do you guys use ? For a turbo D16Z6 mainly street driven @ 15psi ? Track race @ 25+psi ?
For piston to wall, I thought about 0.004
For the upper ring, 0.006, lower .0045 per inch of bore, which come about .020mm and 0.015mm.
I'm not an engine builder, this is what my mecanic recommended me.
By doing some search, this sound about right. Just want to make sure.
Old Apr 1, 2005 | 05:49 PM
turbodohcsi's Avatar
the .015 sounds kinda small, but your pistons should of came with a chart, and calculations to help you figure out the gap
Old Apr 1, 2005 | 08:04 PM
earl's Avatar
Default Re: CP pistons clearance (Civic TSI)
Piston to wall should be .0035"
upper gap .018"
.020" middle
Old Apr 2, 2005 | 03:00 AM
Civic TSI's Avatar
Default Re: CP pistons clearance (earl)
Thank Earl. For piston to wall, we were debating between .0035 and .004. He's used to work with JE and he wanted to go with .005 at first. What makes CP pistons kind of use the same clearance between an N/A and FI ?
Did you revisited your rings clearance ? It's not what you were saying like a year ago ?
Old Apr 2, 2005 | 05:17 AM
earl's Avatar
I believe they use .003" for NA and .0035" for FI.
I have always used the .018" upper gap but have increased the middle gap (per the advice of CP) to .002-.004" larger than the upper gap.
Old Apr 2, 2005 | 08:12 AM
fled's Avatar
JE out of the box recommends piston to wall clearance to be 0.004. Earl, would you care to expand on why you prefer 0.0035? Does it really matter?
Old Apr 2, 2005 | 04:52 PM
earl's Avatar
Default Re: CP pistons clearance (fled)
I just do what CP calls for. I never try to out think them.
Both CP and JE build their desired clearance into the piston. You buy an 84mm piston and you bore your block to exact on 84mm. The clearance is into the piston. I think both CP and JE are smart enough to make that call. Now some of the other piston manufacturers......
Old Apr 3, 2005 | 08:43 AM
fled's Avatar
I did not know that JE built their clearances into the pistons, I thought only CP did that. I thought i had to overbore 81.5mm (piston spec) + 0.004mm (clearance spec)
Ok yeah i just read the spec sheet online carefully and it says that the clearances are built in, but for turbo and similar...additional clearance may be required.
Modified by fled at 9:58 AM 4/3/2005
Old Apr 3, 2005 | 09:07 AM
earl's Avatar
yeah, I guess that would depend on how lean you plan to run your tune-up as to extra clearance. That would be the only reason I could see to increase the specs.
Old Apr 3, 2005 | 10:09 AM
Civic TSI's Avatar
As I said, I'm not an engine builder, more like an engine blower LOL
Just a quick question, what is the difference between .0035 and .004 ? Better compression ? Rings longevity ?
Thanks again for the info.
Old Apr 3, 2005 | 07:45 PM
earl's Avatar
Just more room to expand. Probably no power difference. They could slap a litte on start-up with extra clearance.
hookups214
Jan 28, 2006 10:44 AM
95c1v1cs1
Jul 28, 2004 09:44 AM
nicklk
Jan 27, 2004 12:58 PM
