blitz turbo timer install help
Old Mar 30, 2005 | 05:52 PM
TORQUE MONSTER's Avatar
Default blitz turbo timer install help
I did a bunch of searches but all the posts i've found are pretty old and i'm not getting any response from them. Heres my problem
I got aBlitz FATT Turbo Timer..
I got the wires all connected up accordng to the instructions and everything seems to be fine. The boost gauage and count down works. But the car doesnt stay on after i pull the key. The timer still counts down when the key is removed.
thanks
oe
Old Mar 30, 2005 | 06:02 PM
BoM's Avatar
BoM
Default Re: blitz turbo timer install help (TORQUE MONSTER)
is the ebrake up when you pull the key? bad wiring there?
Old Mar 30, 2005 | 06:54 PM
PrettyLude's Avatar
recheck the wiring again
Old Mar 31, 2005 | 01:07 PM
Default Re: blitz turbo timer install help (BoM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoM &raquo;</TD></TR><TR><TD CLASS="quote">is the ebrake up when you pull the key? bad wiring there? </TD></TR></TABLE>
yes the ebrake is pulled.. but the wierd thing is that if i let go the ebrake the timer does NOT shut off..
Old Mar 31, 2005 | 01:10 PM
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoM &raquo;</TD></TR><TR><TD CLASS="quote">recheck the wiring </TD></TR></TABLE>
wires are checked and rechecked..
greeen ---&gt; ign 1
blue------&gt; ign2 or acc (tried both, but together)
purple -----&gt;ebrake
red--------&gt; const 12v
appearentl while i was messing around with the blue wire by connecting it to other wires, seems to not have an effect..as in the car shuts off when the key is pulled but the timer is counting down.. and the ebrake function is does not shut off the counter..
thanks
Old Mar 31, 2005 | 05:42 PM
PrettyLude's Avatar
did u pin it to the right brake wire (there is only one brake wire) once u drop the ebrake it should shut off kinda like a safety issue
Old Mar 31, 2005 | 09:15 PM
yea i did.. but mines not working.. the ebrake doesnt seem to shut it off..
iNtEgRaGsR19
Jan 25, 2007 07:30 AM
vsm_EJ6
10
Apr 14, 2005 07:26 PM
mickk
Sep 4, 2004 05:21 AM
ebp 99 si
Aug 21, 2003 01:27 PM
GruvyTune
Oct 29, 2001 01:20 PM
