GSR boost question
Old Mar 31, 2005 | 08:29 PM
CRXLST's Avatar
Default GSR boost question
I m running a T3 on a stock GSR with a cometic head gasket 2 lower compression.. I have stock injectors and a VAFC hooked up.. If I richened the fuel up 10% across the RPM range could I run 4psi until I get some DSM injectors??? I m also running a 255 walbro fuel pump!!!
Old Mar 31, 2005 | 08:43 PM
SSBPGSR's Avatar
Default Re: GSR boost question (CRXLST)
i would get some bigger injectors man. even on 4psi thats kinda pushing it.
Old Mar 31, 2005 | 08:44 PM
CRXLST's Avatar
Default Re: GSR boost question (SSBPGSR)
Prelude injectors??
Old Apr 1, 2005 | 01:22 AM
drumking15's Avatar
theyd be better than nothing...
Old Apr 1, 2005 | 02:34 AM
Zakar's Avatar
DSM injectors are going to be a limiting factor especially when you get a bigger turbo
Old Apr 1, 2005 | 05:53 AM
CRXLST's Avatar
I m not going 2 run alot of boost even after I get injectors this is my daily driver... So I think the 345cc prelude injectors will be fine...
Old Apr 1, 2005 | 06:32 AM
PrettyLude's Avatar
you didn't need to lower the compression with that low of boost
Old Apr 1, 2005 | 06:42 AM
citrus3000psi's Avatar
I'd be carefull about boosting on stock injectors...I think honda injectors comes very close to maxing out just in NA state.
Mephistopheles
Feb 15, 2021 05:17 PM
boostcrazy1234
Apr 14, 2008 10:19 AM
TurbodTegSfaria
Nov 14, 2006 04:07 AM
mike70845
Jun 25, 2005 07:53 PM
GahDamnGsr
Nov 2, 2003 05:32 PM
