HELP!!!! REAR Suspension PROBLEM!!!
Old Nov 15, 2009 | 07:53 AM
jdmejcivic's Avatar
Default HELP!!!! REAR Suspension PROBLEM!!!
I just got a 94 integra and the previous owner installed aftermarket lca's (not sure on brand) but it still has stock spring/struts. the rear of the car is very high and the rear wheels toe in causing it to wear on the outside of tire. its very obvious when looking at the rear of it that they're not aligned properly, also for some reason he left the rear sway bar off when doing this. Could somebody please help me and tell me why of the toe issue and what i can do to fix it. thanx in advance
Old Nov 15, 2009 | 07:59 AM
Fibercation's Avatar
Default Re: HELP!!!! REAR Suspension PROBLEM!!!
get a alinement
probly stock struts of some other car if its abnormally high....get some other suspension on there ...drop it and get a camber kit
Old Nov 15, 2009 | 08:10 AM
jdmejcivic's Avatar
Originally Posted by Fibercation
get a alinement
would the sway bar not being on there cause it to do this? Its like the suspension is fully extended, as if it was jacked up????
m1am1sf1n3st
Jan 27, 2010 01:48 PM
specialized108
56
Jan 25, 2009 02:27 PM
envee
Apr 15, 2007 07:25 PM
The Si
Suspension & Brakes
Mar 12, 2007 11:29 PM
