90 Integra LS Code 43
Old Nov 17, 2009 | 05:32 AM
kentwat's Avatar
Default 90 Integra LS Code 43
I did some searching and found fuel system problem. The car is getting very poor mpg and is very sluggish unless I give it a good amount of gas. I found a post that said 43 is mainly the O2 sensor and will show a rich fuel idle mix. The car does have a black sooty color on exhaust tip but doesn't smoke. It is also giving a code 12 for egr lift sensor. Any tips appreciated, I do not like watching my fuel gauge going down so quickly. Thanks.
Old Nov 17, 2009 | 05:35 PM
kentwat's Avatar
Default Re: 90 Integra LS Code 43
No info or leads? Bump.
Old Nov 19, 2009 | 10:03 AM
Steve-o's Avatar
change egr and o2 sensor make sure to clean off the carbon build up were the egr bolts up to u should be ok then
Old Nov 19, 2009 | 03:11 PM
g2daturbo's Avatar
deff need o2 sensor and more than likely egr valve... check connections on valve.. sometimes u can remove and clean the carbon off of it and that will fix ur issue!
Old Nov 19, 2009 | 03:32 PM
ILS_09's Avatar
x2
avrfan
Aug 25, 2014 01:59 AM
haroldthefly91crx
Aug 19, 2007 07:08 PM
JDM_EH2
Oct 20, 2005 11:49 AM
alberto.garrido
Jul 27, 2004 09:33 AM
Btothe3rdDegree
10
Jun 22, 2003 04:51 PM
