What gauge wire to use for battery relocation to the trunk?
Old 11-12-2009, 07:50 PM
92integraVTECgsr's Avatar
Default What gauge wire to use for battery relocation to the trunk?
I have to relocate my battery to the trunk in my 00 Integra GSR. What gauge wire would be the best? I bought a Rockford Fosgate 4ga power wire kit today. I think that should do the job, but I just wanted to make sure.
Old 11-12-2009, 07:53 PM
RESIDENT
TypeRfit's Avatar
Default Re: What gauge wire to use for battery relocation to the trunk?
You are correct sir, at minimum do 4 gauge, i personally ran 2 gauge in mine, but 4 gauge will do the job.
Old 11-12-2009, 08:19 PM
thanks, it was all they had in stock @ work and i needed it today
Old 11-12-2009, 08:56 PM
RESIDENT
TypeRfit's Avatar
Anytime, Did you get good terminals for the kit?
Old 11-12-2009, 09:15 PM
I just got the RF distribution kit so I can connect all my wires under the hood to the power wire and run it to the back.
Old 11-12-2009, 09:17 PM
B16Drag's Avatar
At least a 4 gauge but the smaller the gauge the better.
Old 11-13-2009, 01:06 AM
chaz_w16's Avatar
i put the starter wire and the fuse box wire at 4 gauge and ran them into a big fuse then went 0 gauge back to the battery
Old 11-13-2009, 06:44 AM
RESIDENT
TypeRfit's Avatar
Sweet, You shouldn't have one issue then. Have fun doing it and post up some pics when your done
Old 11-13-2009, 07:50 AM
Bond's Avatar
I used 0. I would suggest to go min4 but 2 or 0 is great. Install a circuit breaker aswell!
Old 11-14-2009, 07:46 AM
Well I ran the 4 gauge and everything is working great so far.
Old 11-14-2009, 08:42 AM
Rediness_code's Avatar
I gotta do this to my car also, how long did you get the wire? how much u pay?
What are you using to hold down the battery in the trunk?
Old 11-14-2009, 10:54 AM
twentyhurtz's Avatar
you mean the lower the gauge # the better.. cause too small of a gauge <4 would be bad... voltage drop, ie.
Old 11-15-2009, 04:47 PM
Bond's Avatar
Do not overlook running a circuit breaker guys. The added length will cuase a higher current draw so put one in to be safe
Also just spend a little extra and get a battery box. One of the best things I bought when doing my relocate.
Old 02-22-2018, 08:33 AM
cubnsensation's Avatar
hey bud, i know i am late to this but i was wondering what size cable did you use to run the power from your fuse box to the battery? assuming you didnt move the battery to the trunk as well.
alex14
14
11-11-2010 12:56 AM
91(si)hatchey
07-29-2009 08:16 AM
essex
06-07-2008 11:11 AM
G2ILS
01-17-2005 12:14 PM
speedemon
01-13-2005 09:43 PM
Quick Reply: What gauge wire to use for battery relocation to the trunk?
