Urgent Help Needed!!!
Old Nov 19, 2009 | 12:17 PM
bradennicely's Avatar
Icon3 Urgent Help Needed!!!
100% stock integra lack of power when first started, it seems that once it gets to normal running temperature it runs normal, but until then it lags alot of power any ideas? its not throwing any codes????
Old Nov 19, 2009 | 12:32 PM
dsdunnavant's Avatar
New User
Default Re: Urgent Help Needed!!!
There is a possiblity that you are losing compression because of worn out piston rings. Once the car warms up they expand and seal properly. This happened to a BMW 325 that i used to autocross.
Other possiblities, Clogged Fuel injectors or worn out injector O-rings.-easy fix
Old Fuel filter
Old spark plug wires (look for corrosion or rust)
Some suggetions.
Old Nov 19, 2009 | 12:33 PM
ek-g6's Avatar
I would check ect sensor, or iat sensor, they both have to do with temperature and how it runs your engine when cold or hot.
Old Nov 19, 2009 | 01:52 PM
Dogginator's Avatar
Daisy... Daisy...
Any details on the car?
Old Nov 19, 2009 | 02:50 PM
ILS_09's Avatar
Check timing too. The car runs like crap if it's off.
dc2ladd
Honda CR-V & Element
Dec 28, 2017 02:35 PM
MurtazaDSM
Oct 18, 2011 12:58 PM
kowekiller
Aug 4, 2006 11:08 AM
docctorwho
Jul 16, 2006 09:04 AM
reza"
Feb 20, 2005 03:42 PM
