trunk makes squeaky noises
Old Nov 15, 2009 | 09:52 PM
heyimrchills's Avatar
Post trunk makes squeaky noises
does anyone know why my integ makes noises while im driving sometimes? is it because its a hatch? or something not strapped down
i really want the noise to end its getting annoying for me and my passengers..
help wanted!!!
Old Nov 15, 2009 | 10:00 PM
ILS_09's Avatar
Default Re: trunk makes squeaky noises
where is the squeaky noise coming from?
Old Nov 16, 2009 | 05:42 AM
5hiz's Avatar
I have the same problem! I think it's from when the plastic interior panels rub against each other when the car shifts from a bump while driving. Maybe some of the clips that hold the panels to the frame might have came loose or broke. Not sure though, waiting to see what other's might think it could be as well
Old Nov 16, 2009 | 12:04 PM
Post Re: trunk makes squeaky noises
it's coming from the trunk not sure exactly though
Old Nov 16, 2009 | 12:05 PM
hmm.. might be not sure.. we'll see what other people say
Old Nov 16, 2009 | 12:09 PM
jdm602's Avatar
try adjusting the loop where the hatch hooks onto. maybe mess with the rubber stop screws. you sure its the trunk? i member on a few of my cars i always thought it was the hatch when it was the sway bar bushings. i needed to scuff them up and clean them. it all went away after that.
Old Nov 16, 2009 | 12:10 PM
TypeRMOBBiN209's Avatar
your sure its not your suspension? i always hear squeaking in my integra in from the trunk area but thats because i need to replace bushings
Old Nov 16, 2009 | 01:11 PM
A.R's Avatar
A.R
im having the same problem with ma DC2, and yes i think its ma trunk but im not sure wat to do.
I have taken out my back dash, trunk board and carpet, and rear seats and panels, all i have in is ma 2 front seats, and i still hear a distinct rattle from the trunk area wen i go over bumps.
my next move is to remove my type R spoiler.
Old Nov 16, 2009 | 02:21 PM
jdm602's Avatar
check the bushings on the suspension and the sway bar. you might be surprised to find thats the problem.
Old Nov 16, 2009 | 08:12 PM
langjairicer's Avatar
ZOMG! I have the exact same problem on my integra. I tried to find the culprit but I ran out of luck. I was pretty sure it was the panel that covers the trunk. I tightened down the bolts but it still squeaks.
Old Nov 16, 2009 | 10:01 PM
PaulMc's Avatar
Painfully Stupid
Ok, this may sound like a really dumb idea, but it works; I've owned 3 Integras in the past before my ITR and I had the same annoying squeeky problem. How I resolved the issue for each car was with just a small druel of saliva into the hatch latch. It worked for all three of my cars, if it's the same noise that I was experiencing, it'll work.
Old Nov 16, 2009 | 10:54 PM
5hiz's Avatar
hmm..saliva.....well that sounds like the "least" expensive way to try and fix it, i'mma try it
Old Nov 17, 2009 | 09:36 AM
PaulMc's Avatar
Painfully Stupid
The inexpensive, quickest, easiest solution! ;-)
Old Nov 17, 2009 | 10:28 AM
jjipson's Avatar
hahaha. thats awesome. my teggy used to do this also but turned out it was my liscence plate. I put some rubber behind it and it stopped. Hope this helps......
Old Nov 17, 2009 | 11:08 AM
where exactly on the latch where you open the trunk and the hook is? put saliva there? aha if its inexpensive ill try! and how much saliva LOL or bushings what exactly is that.
Old Nov 17, 2009 | 11:54 AM
kulo's Avatar
i sometimes get squeaky noises from my es bushings on the sway bar
lke2drvgsr
Nov 4, 2004 09:54 PM
VTECMaster
Nov 4, 2004 05:58 AM
NINJASPY
20
Aug 24, 2003 09:53 PM
