leaks..
Old Nov 11, 2009 | 02:58 PM
smurf357's Avatar
Default leaks..
well my b20 swap 95 integra is leaking...coolant...i checked it wasnt the radiator...it was like coming from under the motor...idk...help
Old Nov 11, 2009 | 08:18 PM
kchungb17a's Avatar
Default Re: leaks..
Pressurize the cooling system and check for the leak. That's the best way to go about it. Probably a bad hose somewhere.
Old Nov 12, 2009 | 11:59 AM
vtec maniac's Avatar
Default Re: leaks..
check d main hose at the back of the engine that runs into the thermostat housein
Old Nov 12, 2009 | 12:18 PM
seanbev24's Avatar
Default Re: leaks..
x2 on pressure testing the system, easiest way to spot a leak.
em1effekt
22
Nov 29, 2011 04:23 PM
jdmboy94
Jan 21, 2009 09:48 PM
hassan21
20
Sep 21, 2007 03:09 AM
yOnKiNaToR
Sep 20, 2006 10:46 AM
Ninety5Ex
Jan 25, 2005 11:57 PM
