integra part?
Old Nov 14, 2009 | 06:47 PM
kojack_0's Avatar
Default integra part?
can anyone identify this part?
its the bar that goes across next to the motor.
above the header with the blue bracket.
and what is the purpose of that?
where do you find one?
thanks.
move if its in the wrong section.
Old Nov 14, 2009 | 07:45 PM
AllMotorDC4's Avatar
Default Re: integra part?
I've never seen that before. .And idk but to me it looks like some sort of torque mount?
Old Nov 14, 2009 | 07:58 PM
hmongyaj87's Avatar
Thats a vortech supercharger. Thats the pulley shaft to the supercharger.
Old Nov 14, 2009 | 08:00 PM
I thought superchargers were on top on the intake manifold?
Old Nov 14, 2009 | 08:25 PM
thumper64's Avatar
Centrifugal supercharger?
Old Nov 14, 2009 | 08:40 PM
GagnarTheUnruly's Avatar
Not the centrifugal kind. It's on the passenger side so it can intercept the stock air intake placement. You can see the aftermarket intake in the upper left corner. The supercharger is connected to the accessory belts by the power steering pump, which is under that blue bracket. The reason the bar runs across is to connect the supercharger on the pass. side of the engine to the belts on the driver side.
A centrifugal supercharger impeller looks like a turbocharger, but instead of being spooled by exhaust pressure, it's spooled by a belt. It also has boost characteristics of a turbo, with psi that increases exponentially with engine speed.
Old Nov 14, 2009 | 09:34 PM
kojack_0's Avatar
ooo sounds interesting. so i guess you can still use the stock intake manifold for this setup.
Old Nov 14, 2009 | 09:41 PM
pkxiong's Avatar
yeah, i think you still can use the stock manifold
Tong.Y
10
Aug 31, 2010 01:52 PM
hmtcrxsir
Oct 14, 2009 10:18 AM
Targa4Life
Mar 10, 2005 07:00 AM
B2FiNiTY
Sep 16, 2003 11:46 AM
Stock R
Feb 1, 2003 02:56 PM
