Question about starter
Old Nov 29, 2009 | 11:50 AM
4drint3gr4's Avatar
Default Question about starter
It seems like my starter spinning/whirring/rapidly.....not clicking...somehow the gear isn't being pushed out? What could be the cause? This starter spins but seems like the gears isn't catching on to start the car. If anyone knows any ideas let me know..how if there's anyway to get the the actual gear to push out and meet with the flywheel teeth? Ive taken the starter to AutoZone and they checked it...they said it worked. yes it spins but does the gear do what it's suppose to?..I'm not sure and I don't trust the bench testing because I've tested a separate starter before and it didn't work when installed in car. Most likely I'll have to purchase a new starter but can't figure y something like this goes out.
Old Nov 29, 2009 | 11:52 AM
4drint3gr4's Avatar
Default Re: Question about starter
is there anyway to make the gears on the starter spin in the opposite direction? It's a dumb question but I guess anything can happen..lol
Old Nov 29, 2009 | 07:37 PM
DOUBTS.72's Avatar
Get a rebiuilt one cost 50$ with your old one in exchange. I feel you if you might be low on money, but better than guessing. I got mine for 46$.looks new ..how long ago since replaced? oh and i don't believe you can make it spin the opposite direction.
Old Nov 29, 2009 | 10:15 PM
4drint3gr4's Avatar
Actually it's not the starter because I put in a known working starter and same results.
Old Dec 5, 2009 | 10:27 PM
bboyj2's Avatar
Has anyone come up with a solution to this problem yet. My car is now reserved to Fred Flintstone startoffs so I know someone has to be knowledgable about a solution to this problem! It's a forum with probably over 100,000 members now, SOMEBODY HELP!
Old Dec 7, 2009 | 08:01 AM
Steven.'s Avatar
How do you know its your starter, any tricks to starting your car?
Are you sure its the starter or the gear it syncs with in the engine?
Old Dec 19, 2009 | 10:44 AM
bboyj2's Avatar
i pop the clutch. only way i can.
Old Dec 22, 2009 | 08:12 PM
98r860's Avatar
The Bendix of the starter is bad. You'll need to get another starter.
Old Dec 22, 2009 | 08:20 PM
b20vtek's Avatar
x2...
Old Dec 24, 2009 | 09:42 AM
4drint3gr4's Avatar
Actually it's not my starter. I tried a known working starter and same thing. Car won't start. Tried good starter and distributors. This sucks. I only barrowed the distributor and now it's dead and it's cold enough where you don't really want to tear the dang car apart. I'm gonna try the ecu just in case that's the prob. Any suggestions anyone? thanks so far
Old Dec 24, 2009 | 10:13 AM
bks84's Avatar
Loved
Its not the ECU.
Take your starter and get it tested.
Check all your power connections; battery, starter, etc.
Old Dec 24, 2009 | 11:45 AM
4drint3gr4's Avatar
Starter is good. Tested it and used someones elses working starter. This situation came about because I had lend my distributor to a cousin. After he returned it, put it back on it wouldn't start up anymore. Distributor still works, works on his car.
Old Dec 24, 2009 | 02:26 PM
kchungb17a's Avatar
You made sure the starter signal wire to the solenoid is connected right? The 18-ish awg wire with the female spade connector? If so check to see if you are getting 12v there in while cranking. If not trace the open.
If that's ok and you're sure the starter is good it may be either the sun ring on the flywheel is broken off or you might have a broken timing belt. Is your crank pulley spinning when you try to start it? If so take the oil cap off and look at the rocker arms when you crank and see if they move. If crank pulley turns and rockers arms don't move = broken t-belt. If your crank pulley is not spinning while cranking then it may be a broken flywheel. Is it aftermarket?
Edit:
just read your last post. If you checked what I posted above and everything is ok then check your connections on the distributor. If you find a bad connection, correct it and remove the spark plugs. Put about a teaspoon of oil into each cylinder. You may have washed down your cylinder walls with fuel with all that cranking.
Old Dec 26, 2009 | 02:48 AM
APCXxstovetopxX's Avatar
if this started after u lent the distributor to someone wouldnt that mean the distributor caused the problem?? seems like you would check that first instead of jumpin on the starter
Old Dec 29, 2009 | 12:03 PM
4drint3gr4's Avatar
i jump to the starter becuz the dist works...but its not the starter neither and the car still wont start..
strinm02
Honda Civic (2006 - 2015)
Jan 2, 2019 04:48 PM
dominate9
Jan 16, 2009 04:32 AM
snzh22
Nov 16, 2008 04:10 PM
SubTitle
Oct 30, 2003 11:04 AM
