gears go in with out pressing clutch (brand new clutch)
well like the title states i just changed the clutch on my b18c5 motor and when i was done bleeding it i turned the car on and tried to put the car in 1st gear with out pressing the clutch and it did go in any ideas what i could be it goes into the all 5 gears
the clutch is a stage one exedy ( it goes into gears while the car is on with out pressing the clutch)
Re: gears go in with out pressing clutch (brank new clutch)
does it try to stall out? are you able to drive the car?
no the car is on the ground and when the car is on it still goes into gear with out pressing the clutch the car just stalls
Daisy... Daisy...
OP, we are confused by what you have posted. Does this car move? Are you jamming it into gear with the car running?
The car is on the ground with the engine running.
With the clutch engaged, you go from neutral into first and the car stalls and dies.
That's normal and not really that good for your car. Have you actually driven your car yet? If you drive properly (i.e. shift with the clutch disengaged and then engage the clutch gradually) does it function? If so, I can't see the problem.
Re: gears go in with out pressing clutch (brand new clutch)
i bought the car as a shell i had the motor in another integra i drove it yes the motor works perfect and so does the tranny but the thing is that when i swapped the motor in the shell (integra) i turned it on everything was perfect everything is conected perfect...
and the problem im having is that i could shift to any gear without pressing the clutch when the car is turned on it has a brand new clutch so i dont think thats the problem anything else that could be causing this
that doesnt make any sence!! are you forcing the car into gear while it is on? if so DONT DO THAT!! and yes make a video!
no i am not forcing it at all it goes in like if the clutch was engaged it does not grind or make any noises when i put it into gear but im not even touching
i had the same problem its the axels check if there pushed in all the way in check the one thats connected to the tranny and check your axel that connects to the half shaft and check if your half shaft is pushed all the way in and make sure the axels are not spinning while the car is on
no i was running that motor before but in another car but this problem happen when i swaped it into another integra
Well, this is not making much sense. Either the car will jam into the gear, let's say first, it will either jerk the car forward and stall or it will continue to run without moving the car. If it continues to run, then you have a problems with either the transmission, clutch or axles.
Honestly, I have no idea why you would even try to put the car into gear without the clutch, you're destroying the synchros in the transmission.
no problem man i now it feels but check your axels double check if u put them on right also check the half shaft is all the way in i been trew this problem before when i did my lsvtec the first day i took it out for some reason i could put my gears in with out the clutch no grind no nothing i poped the hood i saw my axles was spining like crazi i replaced it and everything was back to normal then my boy had a eg hatch with a ls swap hes half shaft poped out a lil bet not much once again all the gears where going in like butter with out using the clutch we jacked it up saw the half shaft poped out banged the **** back in bolt it up and everything was back to normal so yea bro check them axels
