bad catalyst convertor?
Old Dec 2, 2009 | 07:56 PM
tban21's Avatar
Default bad catalyst convertor?
so i just got my cat replaced for an aftermarket high flow cat from magnaflow... i realized that i am burning oil...like a lot too..probably from a valve stem seal leak becuz i did a compression test and a leak down test and it all seems fine. It has only been like 2 weeks and im startin to smell a rotten egg smell? Does that mean my catalyst convertor went bad already?
My car is a 96 integra with a obd1 ls vtec motor...
What could be the problem?
Old Dec 2, 2009 | 08:05 PM
EL Vap133's Avatar
Default Re: bad catalyst convertor?
Sounds like it could be, how is your gas mileage? Any bogging?
Old Dec 2, 2009 | 08:14 PM
tban21's Avatar
horrible...like 20ishh a gallon.. but i just put the cat on? i was running an itr one before this, but since i just got the apexi ws2 i upgraded 2.5 piping and a highflow cat and thats when i started to smell the rotten egg. Is that what a bad cat smells like though?
Old Dec 2, 2009 | 08:17 PM
tban21's Avatar
i was bogging before but that was because i was low on oil...it doesnt seem to bog anymore or no significant rpm drop.
Old Dec 2, 2009 | 08:50 PM
mouab18c1's Avatar
could be a bad o-ring gasket.
Old Dec 2, 2009 | 09:10 PM
tban21's Avatar
mhmm..well i am plannin to pull my motor and rebuild it..picking up some stage 2 cams springs and retainers tomorrow =]... how much are rings?
Old Dec 3, 2009 | 08:24 AM
mouab18c1's Avatar
depends which rings your looking for. do some research
Old Dec 3, 2009 | 12:54 PM
95GSRFullRace's Avatar
If you are doing rings I would do bearings while you are in there!!! May want to think about even honing the block!
Old Dec 3, 2009 | 07:37 PM
tban21's Avatar
yikes...anyone have a rebuild thread or a check off list that they used? i just picked up the stage 2 cams springs and retainers today for 400 ..!! probably gonna need rings, bearings, and all the bs gaskets?
If anyone has their build check off list, that would greatly be apperciated.
Old Dec 7, 2009 | 08:05 AM
Steven.'s Avatar
Could be the smell of something burning doesnt neccasairly mean your cat is bad however i never used an aftermarket cat but cars burning oil or other fluids do have a whiff to em yeah
Old Dec 7, 2009 | 08:17 AM
8VEYBEYB's Avatar
my 08 cobalt with 5000 miles on it did this....
mortificationrock
12
Jan 28, 2010 12:09 PM
DC4 me
Nov 12, 2006 07:03 PM
B-SerioUs EGg
Feb 6, 2006 07:01 PM
G2DAB18
Jun 13, 2005 10:01 PM
Mr. Softee
Nov 2, 2001 12:46 AM
