Car bogs intermittingly
Old Nov 30, 2009 | 02:42 PM
Ex-Eg-Driver's Avatar
Default Car bogs intermittingly
I have a 1996 Acura Integra with a 99 JDM B20 engine. Using a OBD2 P75 ECU.
The car runs fine for a few minutes and then it tends to bog for a few seconds and then suddenly BURST forward, then bogs, and then burst forward.
The smell of gasoline is very potent.
Codes that I have previously found were
IAT-low voltage
IACV- circuit malfunction
RPM fluctuation sensor - no signal.
I have fixed the IAT and the IACV and the RPM fluctuation is due to the crank sensor being missing.
Old Nov 30, 2009 | 03:12 PM
Default Re: Car bogs intermittingly
A little update - Car bogs only when driving, underload.
When in neutral the car revs fine with no bogging.
The car backfires also.
Old Nov 30, 2009 | 03:20 PM
Carl Barker's Avatar
With your update, I get bogging while cruising underload as well, sounds like mines misfiring though (if yours isn't). I've narrowed mine down to a bad injector. Check the fuel system?
Old Nov 30, 2009 | 03:24 PM
Does your car bog then suddenly get a surge of power?
This does sound like a fuel system related problem. With the smell of the gasoline.
Old Nov 30, 2009 | 03:27 PM
Yup, I'll be cruising speeds, give the gas a blip and it will hiccup and RPM's will fluctuate for a second and then a little surge of power afterwards. It hasn't been all the time though, only every once in awhile.
Old Nov 30, 2009 | 04:41 PM
I was wondering if the throttle cable might have something to do with it?
I am using a GSR throttle body and cable on the B20.
Maybe it might be getting stuck and then releasing.
Old Nov 30, 2009 | 04:43 PM
Can't hurt to take a look at, might be a long shot.
Old Nov 30, 2009 | 04:55 PM
Maybe grounds?
Cmon guys throw out some ideas.
Old Nov 30, 2009 | 08:33 PM
Moi Zver' (GSR)'s Avatar
maybe throttle body position sensor broke, if its lowered really low u could have drove over a big bump while acceleration thats what causes it to break and now its reading it at wrong angle, thats what happened to mine and i replaced the sensor and it fixed the problem.
Old Dec 1, 2009 | 01:17 AM
Your car would bog and then surge with power?
I will check this out.
EDIT: I am using a GSR throttle body.
Old Dec 1, 2009 | 12:00 PM
Yea, i was driving from work and hit a big bump(road was cut)and my engine light came on, i was thinking what it could be and i checked the code and it told me throttle position sensor, i replaced it with Blox one and it was fine for about 4 month until i guess it went bad again since my car is sitting so low it could have happened any time. I also have a Vtec controller and i can see the % of throttle im using and when my check engine goes on the Throttle % goes down to 0 and my GSR starts doing the same thing ur does, its of and on thing especially when its cold.
Old Dec 2, 2009 | 07:23 PM
steveo0224's Avatar
New User
I had a similar problem with my car. Under heavy load the car would bog and back fire badly. I came to find out that my spark plug wires were shot. Maybe give the plugs and wires a check. It is simple and just another idea.
Old Dec 30, 2009 | 11:17 AM
HEADS OR TAILS's Avatar
I've read alot of posts about this, and alot of guys have clogged or bent fuel lines. I had the same problem and the fuel line was clogged
Old Dec 31, 2009 | 01:47 PM
'00DC2's Avatar
have you changed your fuel filter? i used to have the same problem acceleration at low rpms 2000-3000rpm would hesitate, boggle, and feel like sht. i changed my dirty *** air filter, and fuel filter made a whole lot of difference! i had 60k on that fuel filter. she now drives like a champ!
MrXclusivE
Nov 23, 2008 09:25 AM
ScandalousCivic
May 12, 2005 07:42 AM
ScandalousCivic
May 10, 2005 06:20 PM
xbn83
Jan 10, 2005 08:07 AM
Daniel G
Oct 13, 2004 05:45 AM
