Header Issues
Old Nov 24, 2009 | 09:10 PM
InvaderTrax's Avatar
Default Header Issues
I was using the factory 90/91 manifold with the O2 sensor at the top. Since it's hard to find one like that, I replaced it with a nice one piece 4-2-1 header with the sensor at the bottom (for 92+). After that, the car has poor idle and bottom end power (1500 to 3000). Above 3000 is fine. I tried resetting the ECU and driving for a few days but it hasn't helped. Is the ECU (OBD0 PR4) just confused because it's reading all 4 cylinders instead of just 1? And that the temp is probably lower 2 feet away? If I get a chipped ECU can it be tuned to better understand the data from the new sensor location? Or is this unrelated?
Old Nov 25, 2009 | 11:05 PM
Default Re: Header Issues
Bump
Old Nov 26, 2009 | 07:38 AM
DAtegLs's Avatar
just get an exhaust shop to weld on an o2 bung up top. thats what i did. i didnt want to because i have a Spoon header but it had to be done. im not sure about the tune thing though. it could be reading wrong because its picking it up from a different place thoguh.
Old Nov 26, 2009 | 08:02 PM
I adjusted my ignition timing and it helped with the idle, but still makes poor power cold down low. If only I could put a heated sensor in
Old Nov 27, 2009 | 01:56 AM
DAtegLs's Avatar
convert it to 4wire bro. i had to on my old crx. its not that hard.
Old Nov 27, 2009 | 10:02 AM
Don't I also have to convert to OBDI to use a 4 wire? Because the PR4 doesn't have the ability to control the heater
kuks24
Jul 31, 2008 01:09 PM
brockscivic
Oct 26, 2006 08:31 AM
jweezy225
Nov 1, 2004 02:44 AM
HybridRexy
15
May 3, 2002 09:49 PM
