maint' req light?
Old Jan 30, 2010 | 07:49 PM
redpreludesi's Avatar
Default maint' req light?
my light is on but i have no idea why because i do not have an owners manual can someone please give me some help
Old Jan 30, 2010 | 08:10 PM
DC2..Type..R's Avatar
Default Re: maint' req light?
on the FAR passenger side of your car, there is a plug with a green cover on the underside of the dash...like i said tho, far side. In that cover, if yours still has the cover...they may already be out of the cover, there is 2 little square outlets close to a half inch wide, 1 of the outlets has two wires, the other outlet has 3 wires. the outlet with two wires you need to wire together by sticking a single wire into both of the holes in the plug....this will allow for the check engine light to flash a engine code to you.
this is assuming your car is an obd1 which is prior to i think 98 and after 90
Old Jan 30, 2010 | 11:06 PM
zedron's Avatar
The main req light is just a light that goes on after a certain amount of miles to notify you it is time for you periodic required maintenance at the dealer. It has nothing to do with a CEL because a CEL is something entirely on it own.
Under the dash on the drivers side you will have a small box with a square button on it. Hold that button down then roll the key to the ON position and hold (the button) for 5-10 seconds. Release the button and turn key off. When you start the car back up it should be off.
OBD1 is 1992-1995
Old Jan 30, 2010 | 11:27 PM
dothacker's Avatar
OBD1 is 1992-1996
but isn't 96 an OBD2? you mean 1991-1995?
Old Jan 30, 2010 | 11:40 PM
zedron's Avatar
Whoops, Fixed
Old Jan 31, 2010 | 07:27 AM
GagnarTheUnruly's Avatar
Just seconding Zedron. Maintainance required light is nothing to worry about. Just reset it and it'll light up again in 5k mi. or whatever.
Old Jan 31, 2010 | 07:30 AM
mrdeadman's Avatar
They let me pick
It's an oil change light to tell you when you need your oil changed. Interval is 7500mi.
To reset it there is a green button right above where your right knee would sit while you are driving. Hold that button and turn the key to II until it goes off.
Next time search first please. The only reason why I answered this is because everyone else is wrong.
Old Feb 26, 2010 | 12:09 PM
thanks everyone foudn the button and changed my oil the lights is now off yaya
lgoodgrace
Apr 27, 2015 03:43 PM
Redcoupe
Jan 12, 2006 08:53 AM
carlos11
Feb 19, 2005 04:03 PM
sweetride
Nov 26, 2004 08:41 AM
Evilducky
Aug 15, 2004 11:26 PM
