Teggy Problems When Accelerating
Old Jan 25, 2010 | 10:03 PM
rarana1j575z's Avatar
Icon4 Teggy Problems When Accelerating
Like It Says When I Go For A Drive Im Starting To Notice That When I Hit The Gas Pedal My Car Feels Like Its Not Getting Any Acceleration Or Fuel Not Sure But Once I Hit The Gas Even More It Starts To Respond And Go.....Let Me Know What It Could Be Thanks.
Old Jan 25, 2010 | 10:07 PM
jimmy o.'s Avatar
Default Re: Teggy Problems When Accelerating
tps....
Old Jan 25, 2010 | 10:20 PM
But I Don't Have Any Check Engine Light On What So Ever
Old Jan 26, 2010 | 11:23 AM
jimmy o.'s Avatar
Light doesn't have to be on for there to be a problem you also didn't mention what it is year trim motor ect...
Old Jan 26, 2010 | 11:30 AM
95 integra's Avatar
Talk about vague details. I can't even tell if you are having mechanical problems or if you just need to tighten your throttle cable....
Old Jan 26, 2010 | 04:00 PM
Well The Year is a 99 Integra LS Engine B18B1 2 Door..........
I Already Tried That Sea Foam But It Didn't Do Anything
I Was Also Thinking It Was Loose But Its Actually Tight
Old Jan 26, 2010 | 06:09 PM
jimmy o.'s Avatar
Automatic or manual???
Old Jan 26, 2010 | 09:52 PM
The Car Is A Manual But Just Can't Seem To Solve This Problem
Old Jan 29, 2010 | 02:30 AM
Honda_ThuGZ's Avatar
clogged cat?
Old Jan 29, 2010 | 02:55 AM
doughboixx's Avatar
im having the same problem ....
Old Jan 29, 2010 | 04:29 AM
dothacker's Avatar
clutch starting to go out?
Old Jan 29, 2010 | 06:09 PM
jimmy o.'s Avatar
^^ sounds possible
the real question is does it rev up and not go for a sec if so you need a clutch
if not check your tps with a volt/ohm meter
Old Jan 30, 2010 | 07:57 AM
Thats A Good Question.........Well Once Im Heading Out Shifting Into Gear I Notice That I Rev And Just For One Or Two Seconds Feels Like It Not Going Then I Give It More Gas And Starts To Respond..........Maybe It Could Be My Clutch Or My TPS But Gonna Check Them Out......Thanx For The Help
Old Jan 30, 2010 | 08:47 AM
dothacker's Avatar
clutch is going out. replace it.
Old Jan 30, 2010 | 09:53 AM
mikekh10a's Avatar
i kinda had this problem too. it was actually my master and slave cylinder leaking..this caused my clutch to not be able to go in gear and my throttle to be less responsive
Old Jan 30, 2010 | 02:18 PM
ShreqBoi's Avatar
i have the same problem, except my clutch doesnt slip. nd im in a 88 integra manual. when i take off, it kinda sputters like its going to die or starving for fuel nd once i get in the range of about 2800-3500 rpms it responds perfectly.
any help?!
sorry for the thread jack op
Old Jan 30, 2010 | 02:27 PM
For Sure I'll Get That Checked Out And Maybe Ya'll Right Might Be My Clutch.........
And Don't Worry About The Thread Its All Good .........But I Have That Same Problem As You To.........But Might Wanna Try And See If Its' your Clutch To Who Knows
Old Jan 31, 2010 | 11:16 AM
ShreqBoi's Avatar
na, it aint my clutch cus it even does it when its in neautral nd i rev it. like it stuters from idle-2800rpms nd starts gettin better til about 3200, then its fine. kinda like its sucking in too much air.
OriginalFive
Honda S2000
18
Jul 18, 2005 12:34 PM
ludee00
Mar 23, 2005 08:53 PM
jonoknut
Feb 24, 2003 06:37 PM
bLuEciVicGuY
Jul 16, 2002 02:49 PM
