tech question obd1 H22a swap in 95integra. please help!!! LS
car runs fine, but when you step on the gas it backfires and sputters. ignition and fuel are good!
any suggestions will help!
timing was off. 2 plugs had anti-freeze on them
it is throwing codes
8-TDC Sensor (Top Dead Center)
defective circuit or unplugged / defective sensor
9-CYP Sensor (Cylinder)
21-VTEC Solenoid Valve
defective circuit or unplugged / defective solenoid valve
Re: tech question obd1 H22a swap in 95integra. please help!!! LS
... O2 sensor? my car was running fine till i put a highflow cat that eliminates the O2 sensor and it starts to backfire... but then again, i also installed a 3" exhaust so that could be my problem too... but check with your sensors.
yea dont think that is it. have a feeling it is timing or maybe a bent valve. just thought i would throw it out there before i pulled the head!
Jwbetley
Engine Management and Tuning
11-15-2008 04:44 PM
No_Limits_Accord
07-09-2008 06:44 PM
