reverse lights help
Old Feb 1, 2010 | 08:46 AM
junior96's Avatar
Default reverse lights help
alright guys i just got had this problem my reverse light don't work no more
i check all the fuse and the bulbs still good now i don't know whats wrong.. any help guys??
Old Feb 1, 2010 | 09:49 AM
junior96's Avatar
Default Re: reverse lights help
dang 6 views??
no help??
Old Feb 1, 2010 | 10:10 AM
dothacker's Avatar
check reverse switch on your transmission, if the fuse and the bulbs are good still.
Old Feb 1, 2010 | 02:36 PM
Sanox's Avatar
This is a long shot but depending if you ever had a leak or if there was water damage, check if the grounds and +12V to the reverse lights are still good or if there is any corrosion on the terminals where the bulbs go.
I had a similar problem with my side marker and tail light on the left... cluster... I guess, was just a rusted through wire where the grounds from each bulb joined into a single wire.
R1chmi3n
Jan 9, 2007 10:09 PM
ejLday
Jul 23, 2006 09:39 PM
booja
Sep 7, 2004 10:20 AM
MPF_supra
Apr 16, 2004 10:32 AM
Blk_prl
Sep 2, 2003 11:34 AM
