fuel injectors
fuel injectors
i have a 97 integra gs stock with just exhuast and intake.
i just bought a t3/t4 turbotecnics turbo kit. along with a skunk2 intake manifold.
my question is do i HAVE to get fuel injectors for my car to run properly with the turbo?
any help would be appreciated.
thanks
-josh
thanks
-josh
Re: fuel injectors
Yes i believe you do need injectors, what size i dont know you need to be more specific as to what you pwer goals are, what does that kit come with? what size trubo is it? research my friend research will take you a long way!
Re: fuel injectors
if you looking at 8psi only then 550cc should be good and give you room to upgrade in the feature. stock injector will run you out to lean which is bad for your motor.
