CEL code 7
Old Jan 30, 2010 | 01:10 PM
jdm_vizionz's Avatar
Default CEL code 7
I just bought a new Omni power tps sensor to replace the old one. But it's still flashing code 7. Do I just follow the line and see if it's unplugged? Or how do i find out if theres a defect in the line? And I just changed the spark plugs, but every time i turn the key, it doesn't start up. It turns but doesn't start up. Any Ideas?
Old Jan 30, 2010 | 07:48 PM
DC2..Type..R's Avatar
Default Re: CEL code 7
I assume you set it to its proper specs....the tps sensors are adjustable on the voltage, if it is not set right, i believe you could be in the negative amount of voltage for idle throttle...which in turn may not let your vehicle start. you have to search for the tps voltage.
luckystryx
Aug 29, 2018 06:15 PM
Jessaaaaay
Nov 7, 2012 06:05 PM
Mugen112
Jun 12, 2009 09:50 AM
A92civicxJDMb16a
Oct 13, 2003 02:29 PM
Neptune
Apr 15, 2003 11:04 AM
