High Idle Problem
Old Feb 2, 2010 | 11:02 AM
Swoops's Avatar
Default High Idle Problem
i have 00 ls integra with a gsr swap i did
with obd2b ls wiring harness
i put a obd2b to obd1 jumper with p72 stock ecu
i been trying to figure this out
i start my car and it runs at 3000K rpm and drops between 1500-3000
if i rev my car or get on the gas hard the rpm tach drops to 0 and then when i let off returns to normal
if i unplug my iac and start my car the idle stays almost consistent at 1500 going up and down about 200rpm and i can plug the iac back in and it will stay running the same
i checked the fitv under the throttle body seemed fine
Old Feb 2, 2010 | 11:10 AM
S2Integra's Avatar
Default Re: High Idle Problem
air intake seems to be the focus of the problem to me, maybe a bad map sensor or it doesn't match the P72 specs. Are you running the ls im or the gsr manifold? I say get a hondata take it to the tuner and your problem can b worked out I think.
Old Feb 2, 2010 | 03:46 PM
4463's Avatar
Clean your IACV if you have not done so already.
Old Feb 2, 2010 | 04:01 PM
Sumslapper's Avatar
Year 3030
tps and map sensor plugs switched? easy to do and will cause this. also check if the throttle body is staying stuck open.
Old Oct 26, 2010 | 07:28 PM
TakeItTo8K's Avatar
I agree with 4463. I had a 95 coupe with a d15b swap and had the same issues. Cleaned the IACV and presto, problem solved.
ah527venom
Jun 7, 2010 11:58 AM
Sil84
May 15, 2008 02:04 PM
libral00
Jun 16, 2007 04:19 PM
guywitaDA
Dec 29, 2005 10:24 PM
mikeunreal
Oct 27, 2005 02:39 PM
