Axle change on an automatic
Old Jan 30, 2010 | 01:04 PM
beanbag's Avatar
Default Axle change on an automatic
For a 99 integra with automatic transmission, will fluid come out if I take out the passenger axle?
Old Jan 30, 2010 | 03:40 PM
mouab18c1's Avatar
Default Re: Axle change on an automatic
it probably wont if the car is not tilted. but it all varies
Old Mar 17, 2010 | 12:31 PM
uo959's Avatar
Im also about to replace my passenger side axle on an auto. Is the same concept as a manual transmission?
Old Mar 17, 2010 | 12:44 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Should be the same. You can try lifting the front right corner of the car only to keep ATF from spilling out. Some may come out, but not as much as it would if both sides of the front end were lifted the same amount.
mouab18c1's Avatar
Yes
shahriar35
Jan 11, 2010 07:57 AM
funtak
Feb 21, 2008 11:31 AM
Hugh Jourgen
26
Sep 14, 2007 07:31 PM
90teg
Jun 27, 2007 06:10 AM
Ronin150
Nov 18, 2004 04:43 PM
