Please Identify this sensor, Vacuum Help!
Old Jan 31, 2010 | 04:54 PM
almostjdmeg's Avatar
Default Please Identify this sensor, Vacuum Help!
What is this sensor that i circled, and i just put an ls in my del sol with this sensor on the IM. My question is where should i hook up this vacuum line on the car. Thanks
Old Jan 31, 2010 | 04:58 PM
Matt93eg's Avatar
Default Re: Please Identify this sensor, Vacuum Help!
IIRC that is called a Purge Valve. And you won't need it for your Del-Sol. You can plug up that nipple on it or take it off and plug the hole thats in the IM.
Old Jan 31, 2010 | 05:03 PM
njmad's Avatar
dont need it
Old Jan 31, 2010 | 05:43 PM
thanks for the responses, i thought that sensor would have something to do with the idle, my problem is my idle is around 100RPMs when i first start it up, then it jumps to about 500. Is there a vacuum line somewhere i need to hook up? Thanks
EF-8SiR
Feb 23, 2009 07:27 PM
K i l l a B e e.
Nov 24, 2008 05:41 AM
welfarepc
Jul 14, 2007 08:07 PM
jaycrxsi
Aug 31, 2006 05:04 PM
musclefella
Apr 15, 2004 09:12 AM
