Help on puting in rocker arms on ls
Old Oct 17, 2010 | 05:03 AM
Built4Battle's Avatar
Default Help on puting in rocker arms on ls
So i built my whole motor so i took everything apart
And when it was time to put everything in i noticed different numbers on every rocker arms on the head and they all had numbers like 2 of each 1 2 3 4 etc
so i thought it didnt matter and put em on in random spots
and when i started the car the valves been ticking loud so i did valve lash and it went little quieter and when i went and did a pull it got loud again so i figured its because of the different spots i put the rockers in
so any one know the correct places for each arm?
thanks.
btw its not a rod knock i triple checked
Old Oct 17, 2010 | 06:51 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Help on puting in rocker arms on ls
You can mix and match them long as you set your lash correctly, its easy to do incorrectly though.
Old Oct 17, 2010 | 06:28 PM
wtf_is_jdm's Avatar
That's what I was curious about as well. I have my head mostly apart (minus the springs and valve assembly)
Thanks!
coltonbarrier
Oct 4, 2013 09:48 PM
B18b-CRX
Apr 21, 2013 11:39 PM
lolv8s
Apr 5, 2013 12:26 PM
Scorchin Civic
Jan 31, 2010 06:22 PM
zbower7
Feb 20, 2004 01:05 PM
