Big teg problem please help!
Old Oct 12, 2010 | 12:00 PM
NFM_Dm's Avatar
Default Big teg problem please help!
94 ls teg with gsr tranny
new clutch kit, flywheel and all the bearings, new master and clutch slave, freshly bled.
Car will be in gear clutch pedal half way pushed in car idles fine. If i push the pedal farther in the car will start rolling forward. Shifts hard when pushed all the way in also grinds. shifts fine when its halfway pushed in.
I just adjusted the pedal. tried it all the way tight and all the way loose.
Old Oct 12, 2010 | 12:04 PM
joss731's Avatar
Default Re: Big teg problem please help!
Threads about to get locked, check ur master cyl.
Old Oct 12, 2010 | 12:14 PM
elliott_holtGSR's Avatar
yeah you could be over extending the pressure plate, adjusting your master cylinder could help solve the problem.
Old Oct 12, 2010 | 12:15 PM
Speed Infliction's Avatar
sounds like the pressure plate is touching the disk. when you adjust the pedal dont put it all they way tight or all the way loose
Old Oct 12, 2010 | 12:33 PM
nsxtasy's Avatar
H-T Order of Merit
You'll find the reason at https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Dc4one8
Transmission & Drivetrain
Mar 23, 2014 10:59 PM
mister.wong
Dec 19, 2007 01:38 AM
0bLiViOuS
Mar 14, 2007 08:55 PM
infamousALLMTR
Jun 30, 2003 11:33 AM
