95 Integra ABS issue
Old Oct 21, 2010 | 01:56 PM
Van-Isle's Avatar
Default 95 Integra ABS issue
Just bought my first Acura, and have been doing everything needed in order to hae a solid daily driver.
Bought it with a ABS light on, was going thru the engine bay to find the modulator. Popped the fusebox cover beside it, and the 10amp fuse for it was pulled.Plugged her back in and started car, ABS light off.. ABS pump sounds like it's constantly running, and made my brake pedal feel/vibrate weird.
Shut the car off and cracked the bleeder, no foam, or air gaps in between spurts. Looked at the resivoir and it looks way low. The fill hole has a tiny little hole in it for the brake fluid to go thru, it would take forever to fill it..
Is there another way to fill the resivoir, and any other common issues to check?
Thanks
Old Oct 21, 2010 | 04:42 PM
Drive 4 fun's Avatar
Default Re: 95 Integra ABS issue
Fuse may have been pulled because the pump ran. Check the codes, several threads on paper clip reset and codes. Probably not a fluid problem, but a pressure problem, accumulator or the pump itself in this age Teg.
Old Oct 22, 2010 | 03:51 AM
DARKNGL's Avatar
I get the code for Pump overrun. Funny though because when wife and I bought it off the person ( 8-9 years ago ) prevous owner had it replaced with a new one from the dealer but it still failed to work. I just ignored it and went on without it.
choithew
Aug 26, 2014 09:25 AM
sikmansherman
May 10, 2011 01:48 PM
EHondaJDM
Dec 14, 2010 05:04 PM
momstaxi
Dec 9, 2006 04:21 PM
90teg
May 2, 2006 08:20 PM
