engine noise
Old Oct 7, 2010 | 08:24 PM
00zzySi's Avatar
Default engine noise
i have a 96 ls integra, these last three days it rained a lot, im not saying thats the cause, however since then the car started making this knocking noise, sounds like its coming from the block, can anyone tell me what it might be?
Old Oct 7, 2010 | 09:04 PM
red96turbols's Avatar
Default Re: engine noise
Trolls are trapped inside...
Is there oil in it?
or just the trolls...
Old Oct 7, 2010 | 09:33 PM
00zzySi's Avatar
what are trolls? if your asking if the car has oil yes it does?
Old Oct 7, 2010 | 09:34 PM
00zzySi's Avatar
is it bad to drive my car like that? how can i fix it?
Old Oct 7, 2010 | 09:42 PM
^^^^ Trolls.
If its a knocking noise, I wouldn't drive it. Take a long screw driver, put the metal tip on the block and the handle in your ear (I'm serious) and see if its coming from the head or the crank. Either way, I wouldn't mob deep with it.
Old Oct 7, 2010 | 10:46 PM
Can you post a video of it? Is it when ever its running, only when driving? How many miles are on it?
Old Oct 8, 2010 | 11:11 AM
00zzySi's Avatar
the noise is obvious as soon the car turns on, it has about 130,000
Old Oct 8, 2010 | 11:17 AM
JdmTypeRdc2's Avatar
Could be rod knock by the way you described it.
Red96turbols is right, put a screw driver to the block and see if the noise is coming from there. If it is, dont drive it and get it checked out. Rod bearings might be worn or on the verge of breaking.
Old Oct 8, 2010 | 11:27 AM
Cripton805's Avatar
Does it have an aftermarket intake? cold air or short ram?
hopefully you didnt get water in your engine. Maybe you didnt hydrolock, but caused damage to the valves or something.
blue_egsi
Jun 16, 2013 11:40 PM
JOS-EM1
26
Dec 29, 2009 06:26 AM
slowassciv33
Sep 12, 2006 12:25 PM
Shaun
20
Mar 19, 2003 03:24 PM
