Fuel problem?
Old Oct 19, 2010 | 03:46 PM
JorgeD1990's Avatar
Default Fuel problem?
94 acura integra b18a1 swap. OK so today i tried starting my car mind you i just put the motor together, well i tried starting it it ran for about a couple of second then i turned it off cause i dont have oil in there well i tried starting it again and it didnt start at all so now everytime i try and start it i hear a little putt the just the engine cranking over so i checked the spark it sparks the fuel pump runs i checked that too plus my fuel filter has a gauge on there that goes to about 45psi can anybody help me out?
Old Oct 19, 2010 | 03:52 PM
EHondaJDM's Avatar
Default Re: Fuel problem?
are you kidding you just put a engine together and didnt put oil in before starting??
Old Oct 19, 2010 | 04:05 PM
1998GsRIntegra's Avatar
Well put. No oil plus brand new motor = stupidity. Sorry but major to you.
Old Oct 19, 2010 | 05:47 PM
blown_ss's Avatar
the no oil thing is most likely the problem but i would check the timing too. you have everything for the engine to run (i hope now you have oil) so check the timing.
Old Oct 19, 2010 | 08:22 PM
JorgeD1990's Avatar
Thx blown ss for not being childish like the other two and yes i just got money for a filter so i will be adding oil and i was looking my exhaust is acctually of by a tooth or two so maybe that will also be fixed but could that be the prblem?
Old Oct 20, 2010 | 04:37 AM
EHondaJDM's Avatar
WHY SO SERIOUS?
If having a sense of humor is childish than i guess so.
There's probaly a ton of metal shavings in you engine now that are gonna go around and tear up your bearings and internals.
You should've never turned your engine over with no oil, it won't break in right eather
Most likely the putt is from the timing, id watch out you might be smackin a valve to a piston, which can cause structural failure
Old Oct 20, 2010 | 10:54 AM
koss1229's Avatar
Another one bites the dust! Rip B18A1...
Old Oct 20, 2010 | 11:21 AM
fcm's Avatar
fcm
Old Fart
So sad, too bad, I would not try anything with that engine until it has had a complete tear down and inspection. 94
Old Oct 20, 2010 | 11:40 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
WTF made you think running an engine with no oil would be a good idea?
You do know the purpose of oil right?
Now you had tons of metal on metal contact, not to mention HOT metal on metal contact, lucky it didn't blow up.
Drop your oil pan, it should look like silver confetti!
Old Oct 20, 2010 | 11:43 AM
Thats a sig.
Old Oct 20, 2010 | 12:15 PM
dudesitsjdm's Avatar
........WOW I BET YOU PUT WATER IN THE MOTOR TO MAKE UP FOR NOT HAVING OIL.
Old Oct 20, 2010 | 12:16 PM
Integra4lyfe069's Avatar
ROFL all u need now is to take the fluid out of the tranny n 2 outta 4 hood hinge bolts n u got mad hp y0.
on a serious note, i would seriously be pissed right now if I were you.
Old Oct 20, 2010 | 12:19 PM
stoneys88hatch's Avatar
need help with a 88 hatch can anyone help???
[QUOTE=on a serious note, i would seriously be pissed right now if I were you.[/QUOTE]
HE think's he isnt getting enough fuel.So he might just pour gas though the throttle body and cross his finger's.Also how can you tell by looking at your cam gear's that it is off on the exhaust by two teeth?I mean really is that possible at all?
Old Oct 20, 2010 | 12:20 PM
Mattb16teg's Avatar
Community Builder
Had to do it:
Old Oct 20, 2010 | 03:15 PM
Laughing my f***ing a** off. haha
Old Oct 20, 2010 | 03:41 PM
rocky_piper's Avatar
kiss that b18 good bye. LMAO
Old Oct 20, 2010 | 07:02 PM
JorgeD1990's Avatar
toall of you i wasnt running it without out oil i just cranked it without adding alot since i didnt have a filter but i have found out the problem it was the cap that goes at the end of the harnest for the fuel injectors i took it off not thinking anything of it so SUCK IT
Old Oct 20, 2010 | 08:12 PM
You fail at honda's!
Old Oct 20, 2010 | 09:37 PM
EHondaJDM's Avatar
oh so any oil that u did put in shot right out the filter port cause that's where it goes before it flows to the internals.
Not makin yourself look any smarter....
...previous post....
Yous guys smell that??
Reeks of bullshit
Old Oct 20, 2010 | 09:43 PM
vtecdc4's Avatar
wow my 6 year old bro knows not to run a engine without oil
Old Oct 21, 2010 | 12:02 AM
h23vtec_dc2's Avatar
this gave me a good laugh before i head to bed....
thanks JorgeD1990
Old Oct 21, 2010 | 04:30 AM
Mattb16teg's Avatar
Community Builder
How quickly the story changes....................
Old Oct 21, 2010 | 08:23 AM
[IMG][/IMG]
[IMG][/IMG]
Old Oct 21, 2010 | 08:25 AM
[IMG][/IMG]
