No Fire
Old Oct 14, 2010 | 06:17 AM
rogersbm82's Avatar
Default No Fire
So I have a no fire situation. A little background. Car would not start one day. Replaced dizzy cap, rotor, ignition control module, wires, and plugs. Car runs great for about 3 days. Car won't start again. Check coil resistance. Just outside of tolerance. I replace that. Car still will not start.
What else can I check? Would any of the sensors (cam, crank) cause it not fire. If so, how do I check those?
Thanks
Old Oct 14, 2010 | 08:19 AM
rogersbm82's Avatar
Default Re: No Fire
Ok update. Problem solved. I checked the sensors. They all checked good. Still was not getting spark. Checked the brand new coil (from autozone) it was out of tolerance, should have been .6 -.8 ohms across the primary terminals. It was .9. Took it back to autozone, they checked it and said it was good. I asked them to exchange it anyways. They did. Put the new one in the car and wallah. Car fired right up.
Garcia505
14
Jul 10, 2013 06:23 PM
jspeedy
Mar 31, 2010 01:25 AM
QUAIJAI
Jan 27, 2005 04:12 PM
infinate bound
Mar 19, 2004 02:25 PM
ion_four
Oct 25, 2002 11:58 PM
