help!!!!!!!!!!!! DA bogging
Old Oct 17, 2010 | 03:17 PM
vtec@4000rpm's Avatar
Icon3 help!!!!!!!!!!!! DA bogging
i have a 1990 acura integra ls with a b16a swap. one day I was checking stuff in my car when my cusin caim and disconnected the spark plug cable from the distributor #4 spark plug cable. idk y he did that. i guess he got shocked really bad thats wat he gets. i put the spark plug cable on again and turned my car on. when i was backing out my car started bogging then turned off, i would turned the key and it would crank but nothing. so i parked it again(pushing it) i when to my friends house and on a stop it started boging again and turned off like i would pump the gas and nothing it wouldnt go over 2000rpm it turned off the i turned it back off. before getiing to my friends it started boging again and turned off and thats where it didnt wanna turn on anymore so i had to push it. i replaced the fuel filter cuz it sounded like it wasnt getting any gas. and that didnt do the trick. i checked the spark plugs and the second one from the left was burned so i replaced it. that didnt work. people tell me it could be my coils or my distributos idk hopefully u guys could help me asap thanks
Old Oct 17, 2010 | 03:31 PM
Targa250R's Avatar
be professional
Default Re: help!!!!!!!!!!!! DA bogging
Check for spark. Remove a spark plug from the cylinder head, then reinsert it into the end of the spark plug wire. Hold the ground electrode against a bit of bare metal in the engine bay (a valve cover nut will work) and look for fat blue sparks while someone else cranks the engine. Don't get zapped; it will hurt. If the spark is weak and yellow/orange, check for worn ignition components (distributor cap and rotor, plugs, wires). If the spark is non-existant, you probably have a bad ignition coil or ignitor (a.k.a. ignition control module).
Old Oct 17, 2010 | 05:39 PM
el crapitan's Avatar
well, seeing as how this occurred immediately after your cousin pulled one of the wires, and you found 1 possibly fouled plug, i'd say the plug wire probably wasn't pushed in enough when it was put back. did it click in? i mean, would be the most logical bet.
Old Oct 18, 2010 | 07:12 PM
Honda_ThuGZ's Avatar
ignition coil or ignitor x2
make sure your wires are on correctly check the firing order make sure no wires got put back in the wrong order
Old Oct 19, 2010 | 08:27 PM
thats guys yea and ill check it out and also yea it clicked i have a feeling its gonna be the ignition coil but ima check i miss driving her. and do u guys know how to run the vtec wire to the ecu cuz my vtec wire is not going thru the ecu, or do u guys kniow a web site i could check out? thanks
BizKut77❤myCB7
Engine Management and Tuning
Apr 27, 2017 08:57 AM
fallingxlove
12
May 30, 2009 04:55 PM
junior40er
May 26, 2009 12:23 AM
bobafreaklx
Mar 1, 2007 06:57 PM
Steve90HB
Aug 26, 2003 05:45 AM
