CODE for HEADUNIT please help me!!
Old Jun 20, 2002 | 10:36 AM
maderfacker's Avatar
Default CODE for HEADUNIT please help me!!
i need the code for my headunit...i just bought the car and i had to un hook my batterey and theres no manual or anything that i know of which would have the code...please help me! TIA!
Old Jun 20, 2002 | 10:41 AM
svtec's Avatar
L D E S
Default Re: CODE for HEADUNIT please help me!! (maderfacker)
mine was underneath the main ashtray on a little sticker. if that doesn't work i'm sure you could go to your local acura dealer and they will square you away.
Old Jun 20, 2002 | 10:43 AM
TEG98's Avatar
Default Re: CODE for HEADUNIT please help me!! (svtec)
did you recieve the owners manual with your purchase look for a card in there with the code written on it. Thats how I got mine
Old Jun 20, 2002 | 10:53 AM
GSRaCeRbOI's Avatar
Default Re: CODE for HEADUNIT please help me!! (TEG98)
yeah see if that card is in your owners manual.. if not.. look in your glove box, under the ash tray or trunk lid.. sometimes theres a sticker w/ the code.. if not your going to have to have the dealer pull the code for you..
Old Jun 20, 2002 | 11:05 AM
Shft@9GSR's Avatar
if nothing else, get the serial number off the head unit, and call acura dealership. they can look it up.
That is how I got mine working.
Old Jun 20, 2002 | 01:14 PM
Max Psi GSR's Avatar
Default Re: CODE for HEADUNIT please help me!! (Shft@9GSR)
Heres a long shot......
Look under the hood in your "fuse box". I believe its on the passenger side near the battery. When i worked at our Acura dealer, all our techs wrote the code down and put it on the underside of the fuse box cover.
Good luck.
But if that fails, just call the Acura P's dept and let them give you the yada yada spill.
Old Jun 20, 2002 | 02:10 PM
vtecnologist1's Avatar
Default Re: CODE for HEADUNIT please help me!! (Max Psi GSR)
ya call acura
theyll charge you like 75 bucks for the code
ditch the stock radio and just get an a/m headunit
Old Jun 20, 2002 | 03:38 PM
samagon's Avatar
Default Re: CODE for HEADUNIT please help me!! (vtecnologist1)
ya call acura
ummm, I don't know what dealer you are going to, but you should report them to honda of america, they should look up the code at no charge for whoever owns the car.
Old Jun 20, 2002 | 03:47 PM
jgrotkier's Avatar
Default Re: CODE for HEADUNIT please help me!! (samagon)
yeah, someones getting ripped off if they want 75 bucks for a code. Maybe they want $75 to take it out and get the serial number off the bottom, either way they are still ripping you off because you can just lay on your back and read the serial number on the bottom of the radio.
Old Jun 20, 2002 | 03:53 PM
94mugenintegra's Avatar
Default Re: CODE for HEADUNIT please help me!! (jgrotkier)
do this and you will get the code, its the only way unless it is hidden somewhere in the car... Find out where the car was originaly purchased from, A acura dealership then tell them to search the vin.. You will have then found the code
Old Jun 20, 2002 | 07:04 PM
JDMTEG98's Avatar
Default Re: CODE for HEADUNIT please help me!! (94mugenintegra)
Don't pay for it. This should be a free service. This code being lost is very common
Smooth4Lyfe
Acura TL, RL & ZDX
Jun 4, 2011 12:56 PM
manyakiexpi
Honda Civic (2006 - 2015)
28
Mar 5, 2007 11:24 AM
Sticky GreeNZ
Jul 28, 2005 05:10 AM
delacampos
Jul 3, 2002 07:21 PM
