how easy is ls/vtec?
Old Jun 17, 2002 | 05:30 AM
comptechgsr's Avatar
Default how easy is ls/vtec?
just as easy as putting an ITR head on an ls block?
wut about ecu, install etc?
Old Jun 17, 2002 | 06:03 AM
b18b98's Avatar
Default Re: how easy is ls/vtec? (comptechgsr)
http://www.c-speedracing.com/howto/lsvtec/lsvtec.html
http://www.b20vtec.com/
i hope these help.
[Modified by b18b98, 10:05 AM 6/17/2002]
Old Jun 17, 2002 | 06:20 AM
vtecdc2's Avatar
Default Re: how easy is ls/vtec? (b18b98)
u need to have an oil line drilled.
Old Jun 17, 2002 | 07:16 AM
MikeSarr_GSR's Avatar
Default Re: how easy is ls/vtec? (HoL Lee SHieT)
yea just take it from a crackerjack box and glue it on there.
instant bolt on without any changes!
> dont expect plug and play...
Old Jun 17, 2002 | 09:44 AM
DX Generation's Avatar
Default Re: how easy is ls/vtec? (MikeSarr_GSR)
Yep, and when you do it, make sure everything is sealed really well. I can't count the number of stories I've heard about oil leaks...
Old Jun 17, 2002 | 01:03 PM
JDMCRVTEC's Avatar
its easy just get the dowel pins moved to the other side need to bore out to 14mm first then need to blcok the oil hole from where the vtec solenoid gets the oil i use a brass plug because it will never leak i ahev seen aluminum plugs leak, brass will expand so you don't have to worry then you need to run a external oil line from the head to the bloclk and use a ls head gasket.
Old Jun 17, 2002 | 01:04 PM
shermanyang's Avatar
IT's EASY as pie!!
Dunc
Aug 2, 2007 08:18 PM
Superdragr45
Jul 26, 2005 06:02 PM
Slimm-rw-
Sep 10, 2004 08:04 PM
drumking15
May 14, 2003 10:06 AM
VXpride
Jun 13, 2002 05:05 PM
