Negative camber?
Old Aug 9, 2002 | 12:43 AM
Increased1's Avatar
Default Negative camber?
I lowered my car a little bit with coilovers but I would like to drop it somemore. Would negative camber have a negative affect on my 1/4 mile time?
Old Aug 9, 2002 | 02:35 AM
ragejed's Avatar
Default Re: Negative camber? (Increased1)
lol. Just a negitive effect on your tires from what I know.
Old Aug 9, 2002 | 02:38 AM
VTi NA's Avatar
Um, unless your camber is like extremely negative, and I mean so much that your tire isn't making full contact to the ground, then no it should not affect your 1/4 mile time.
Old Aug 9, 2002 | 06:10 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Make sure you get the car aligned after adjusting those coilovers, otherwise the toe-in will be out of spec and will eat your tires.
Old Aug 9, 2002 | 06:40 AM
X2BOARD's Avatar
Default Re: Negative camber? (PatrickGSR94)
Hard launches and negative camber don't go well together... I mean.. your car won't die, but it's always best to have your camber close to 0. Negative camber is better for RWD cars than FWD cars.
X2
Old Aug 9, 2002 | 08:00 AM
bullz's Avatar
True I would do that right away... Tires get hella expensive if you ignore it.
Old Aug 9, 2002 | 08:51 AM
Jesse H's Avatar
Default Re: Negative camber? (X2BOARD)
X2
says who
Old Aug 9, 2002 | 09:02 AM
RC211V's Avatar
Default Re: Negative camber? (Jesse H)
i wanna know who to. but negative camber isnt always bad thing. just depends on your style of driving. do you drag, autox, or street all depends. i actually like negative camber to a extent because it actually helps in turn in and in the turn. just wears tires a little faster if you dont rotate. rotate rotate rotate
Old Aug 9, 2002 | 09:49 AM
Jesse H's Avatar
Default Re: Negative camber? (JDMintegGSR)
exactly.
I'd be kind of upset if I lowered my car and negative camber wasn't a result. It's one of the perks.
Old Aug 9, 2002 | 09:52 AM
Civic1992DX's Avatar
Negative camber helps in the turns but hurts in the drag. For drag setup you want your tires to sit straight up (camber = 0) & for AutoX or road race you'd want some negative camber (-2deg or so).
Yuri K
Old Aug 9, 2002 | 01:01 PM
Vazquez911's Avatar
exactly.
Some of these guys don't realize that there are forms of racing where you turn in BOTH directions!
oRANge COnEs oWnZ j00!
Old Aug 9, 2002 | 01:42 PM
slickboy's Avatar
New User
Default Re: Negative camber? (Vazquez911)
Camber isn't what kills tires..it's bad toe that kills tires. I've seen guys run with a good bit of negative camber that don't eat tires. Make sure to get it aligned after you lower it more...and remember, regular tire rotation is key.
[Modified by slickboy, 10:42 PM 8/9/2002]
PhatRoyale
Suspension & Brakes
Jul 6, 2008 06:41 AM
tekstyle
20
Oct 29, 2004 09:12 PM
lowrightor
Dec 13, 2003 10:40 AM
todds94teg
Sep 5, 2003 06:14 AM
SMC Integra
Jul 30, 2003 01:49 PM
