What do you guys do?
Old Aug 12, 2002 | 10:19 AM
KraZyCHOWMEIN's Avatar
Default What do you guys do?
after parking your car, do u
A) leave the car in neutral and put the e-brake up
or
B) put the car in first and apply the e-brake
cause i heard putting the car in gear when parked is better for the forks, is this true or false?
Old Aug 12, 2002 | 10:21 AM
Audi A4's Avatar
Default Re: What do you guys do? (KraZyCHOWMEIN)
well being that im boostin, i leave it in neutral so that the timer will count down
Old Aug 12, 2002 | 10:36 AM
Duckz's Avatar
if my memory serves me right this topic was recently a poll, so if you want way more opinions than will serve you any good pull it up with a search. I personally use the e-brake, or the e-brake + 1st if im on a big hill or something. I'm too forgetful to leave it in 1st, dont want to end up hitting a parked car because im an idiot
Old Aug 12, 2002 | 10:37 AM
SC94DB8's Avatar
Default Re: What do you guys do? (DRAG lll INTEGRA)
I use the e-brake to hold the weight of the car, then put it in first as added protection. I just dont like the weight of my car being held by the mounts. (Would just parking with the car in gear cause premature wear on the motor mounts???)
Old Aug 12, 2002 | 10:58 AM
fuguman's Avatar
New User
Default Re: What do you guys do? (SC94DB8)
same here
press clutch put in first
kill ignition
put on ebrake
let go of clutch
although sometimes i get into the car and only my ebrake is on
i either forget or i have gremlins in my car
Old Aug 12, 2002 | 11:03 AM
SIK IN DA HED's Avatar
New User
Default Re: What do you guys do? (fuguman)
if anything... puttin on the ebrake, then putting it into gear is the best way... doesnt matter if you hold the clutch down before shutting down the engine.
Old Aug 12, 2002 | 11:16 AM
fuguman's Avatar
New User
Default Re: What do you guys do? (dlplayboy)
oh, i know, but usualy you have your foot on the clutch while parking so why press it twice (its a honda but its not invincible, dont over use things , you treat it nice it will treat you nice)
Old Aug 12, 2002 | 01:08 PM
fergy016's Avatar
i leave it in first gear or second because to start the car you must push the clutch in. just make sure when you get your baby started to take it out of gear. it is safer to have both the e-brake and in gear. just habbit of how i learned to drive.
OneOhNine27
Oct 28, 2006 04:02 AM
MR. BAR
Apr 21, 2005 02:16 PM
DarkCyde SI
May 23, 2003 10:33 PM
fire7882
16
Mar 25, 2002 03:56 PM
jamal-188
Audio / Security / Video
Feb 21, 2002 06:55 PM
