spring bolts, needed?
Old Aug 7, 2002 | 07:14 PM
crizmotek's Avatar
Default spring bolts, needed?
ok, im refering to the spring bolts at the cat and the downpipe, what are they useful for? the deal is i have a complete aftermarket exahust system; header, cat, and greddy exhaust. the oem springs that i put back in place are causing me problems. the downpipe and cat just cant get snug enough. a gap occures when ever I press hard on the gas and you can hear and feel the leak. I am certain it is from that spot, i have done extensive research into that. the springs are completely compressed by the way. I have some shorter bolts and some washers and I figure I must do without the springs to get a snug fit and stop my exhaust leak. so what are the negatives of doing without the springs? thanks in advance.
Old Aug 7, 2002 | 07:49 PM
lsteggy's Avatar
Default Re: spring bolts, needed? (crizmotek)
i wouldnt do it. i stripped one and just put a regular screw and bolt in there and it made a horrible rattling noise
Old Aug 7, 2002 | 07:53 PM
crizmotek's Avatar
Default Re: spring bolts, needed? (lsteggy)
i dont know how it would make a difference for me though. like i said, the springs are completly compressed. so basicly its as if there is just a piece of solid medal in between. if the springs are suppose to be some type of cushion or stress reliever they arent exactly working in that manner right now.
Old Aug 7, 2002 | 11:08 PM
Kyoung05's Avatar
When I changed my exhaust a while back I thought I needed new spring nuts because the factory exhaust used them. So I went to the hardware store and assembled something similar. Doesn't cost too much, but seriously, a regular nut would work just the same.
Old Aug 7, 2002 | 11:22 PM
ingrate's Avatar
25 Year Member
Default Re: spring bolts, needed? (Kyoung05)
maybe you could find another set of spring bolts and shorten them so they won't compress all the way when you tighten them
journeyquest
Apr 14, 2011 04:35 AM
mikeunreal2
Feb 28, 2006 02:18 PM
microsoft_sux
Mar 28, 2005 02:58 AM
SleepnCiViC
Jan 10, 2004 06:50 PM
chankyeyes
14
Sep 9, 2003 03:39 PM
