squeeky clutch pedal, what was the fix?
I can't remember what the fix for this was, and OF COURSE searching comes up with nothing (damn zeroforum search function ). When I press my clutch pedal, it makes a squeek just before it gets all the way down. I noticed a bit of brake fluid leaking on the inside of the firewall, above the dead pedal, where the clutch rod goes through the firewall. Seems like I remember this had something to do with it, but I'm not sure. Any comments/suggestions?
Re: squeeky clutch pedal, what was the fix? (PatrickGSR94)
have someone press the clutch while you listen near the slave cylinder. if the noise is coming from there, you're supposed to grease up the rod that's in there.
