V-tec conversion
Old Aug 8, 2002 | 09:48 PM
MooreBoost's Avatar
Default V-tec conversion
Total cost, whole shabang, what kinda money are you talking about for a vtec swap onto an ls block. Would it be worth it?
gmoore
Old Aug 8, 2002 | 09:53 PM
b18cya's Avatar
Default Re: V-tec conversion (gmoore379)
its called the frrankenstein engine, hunda tuning & thuper street had a real in-depth article about it several months ago. it might still be up on one of their sites
Old Aug 8, 2002 | 09:57 PM
Leimokei's Avatar
New User
1400 for parts and labor...u probably want to get a gsr/si tranny...new a ex ecu...with a programmed chip or hondata...get new injectors...also
Old Aug 9, 2002 | 06:49 AM
X2BOARD's Avatar
Default Re: V-tec conversion (Leimokei)
You'll need to rebuild the motor...IMO.. just slapping on the vtec head will not be sufficient... just doing that should run you about $1400 as mentioned, but you will be stuck with the LS pistons 9:1 or 9.2:1... when a GSR runs 10:1 You prolly won't even be as fast as a GSR with that low compression ratio.
You'll nned to swap your rod bolts for ARP units as well... a GOOD LSVT setup will run you about $2K - $2.5K.
X2
yyourb0yy
Dec 12, 2012 06:42 PM
crkelly
Jan 20, 2010 11:52 AM
lilxchris
12
Mar 27, 2009 05:44 PM
jimburt3rd
Dec 19, 2008 10:49 AM
AIWFCIATR
Nov 19, 2004 02:34 AM
