Next Mod
Old Aug 7, 2002 | 03:38 PM
MooreBoost's Avatar
Default Next Mod
I have the following on my LS- JRSC, JR High Flow fuel pump, Tanabe Racing Medallion cat-back, DC Sports headers, AEM CAI, and a PowerCore cat on the way. What do you reccomend for my next mod? S-AFC?
gmoore
Old Aug 7, 2002 | 03:45 PM
StyleTEG's Avatar
Default Re: Next Mod (gmoore379)
Yes, I would say S-AFC
Also, cut your AEM CAI and turn it into a short ram.
Those CAI systems are great for NA applications, but do more harm than good on a supercharged setup. The taper to the larger diameter drops the air velocity, raising the pressure the throttle body "sees." High pressure and low velocity are what the throttle body thrives on. Because the blower does heat the incoming air, the engine no longer sees the benefits of the CAI system. Simply put, velocity helps NA engines fill the cylinders, and the losses that come from the additional suction required to pull air through a long tube is overcome by this. Once the air is moving, it has momentum and this helps "push" it into the cylinders. On a blown engine, velocity does NOT help fill the cylinders. There are rotors there. All velocity does is make the air less dense, and this means less efficient air compression.
[Modified by StyleTEG, 12:50 AM 8/8/2002]
Old Aug 7, 2002 | 05:56 PM
aCuRaLsTuRbO's Avatar
Default Re: Next Mod (StyleTEG)
What do you run in the 1/4 gmoore?
Old Aug 7, 2002 | 07:40 PM
MooreBoost's Avatar
Default Re: Next Mod (aCuRaLsTuRbO)
Im yet to get to the track after I have installed my fuel pump so I'm not sure. Anybody else putting their money on an S-AFC?
gmoore
Old Aug 7, 2002 | 07:46 PM
SIK IN DA HED's Avatar
New User
i recommend goin to the dyno so you know where youre runnin at this point.
Old Aug 7, 2002 | 07:47 PM
MooreBoost's Avatar
Default Re: Next Mod (dlplayboy)
And who can cut my CAI to a short ram?
gmoore
Old Aug 8, 2002 | 08:13 AM
MooreBoost's Avatar
Could I cut my CAI to a short ram? Where exactly should the filter end up after I do? ANYBODY PUTTING THEIR MONEY ON AN SAFC?
gmoore
Old Aug 8, 2002 | 09:42 AM
StyleTEG's Avatar
Just cut the CAI so that the filter will fit with out touching the radiator
Old Aug 8, 2002 | 09:47 AM
samagon's Avatar
injectors, FPR, AFC, DYNO.
not nessisarily in that order.
Old Aug 8, 2002 | 02:48 PM
baonest's Avatar
gmoore
my money is there i guess...
Old Aug 8, 2002 | 04:13 PM
Turbo Miniskirt's Avatar
Default Re: Next Mod (baonest)
Injectors, upgraded pully and hondata
msc1kryptonite
Honda Civic (2001 - 2005)
Apr 13, 2009 01:35 PM
slammedteg
Jul 9, 2004 11:56 AM
DeDonDeRosa
Jul 23, 2003 07:23 PM
MooreBoost
Jul 15, 2002 02:39 PM
sig
Mar 20, 2002 07:58 PM
