Help? Car bogs
Old Aug 11, 2002 | 10:22 PM
wannabexsi's Avatar
Default Help? Car bogs
My friend has recently purchased a 92 Integra GS-R. The car seems to have a small bog to it when you accelerate hard. It bogs from 1000 RPM all the way until V-TEC engagement which is about 5500 RPM. We changed the plugs, plug wires, distributer cap and rotor. We noticed that the distributer timing looked all the way retarded so we set that to the center and it still bogs in the same RPM range. I have also unpluged the connectors to the ignitor and spread dialectric grease on the ends and plugged the connectors back in as tight as possible. It felt like it was running perfect for about 1hr. and then started bogging again. If anyone has anymore suggestions then please help. I feel like nothing is working.
Old Aug 12, 2002 | 07:19 AM
4doorRS5spd's Avatar
New User
Default Re: Help? Car bogs (wannabexsi)
Could be a timing related issue. Especially since after you played with it it worked for a time. This may sound stupid, but did you check the air filter? It might need a good cleaning or a replacement.
Old Aug 12, 2002 | 07:44 AM
Audi A4's Avatar
Default Re: Help? Car bogs (4doorLS5spd)
o2 sensor
Old Aug 12, 2002 | 09:43 PM
wannabexsi's Avatar
The car has an after market intake that was bought recently and is clean. Sorry I didn't mention this before.
Old Aug 12, 2002 | 11:06 PM
Hapa DC5's Avatar
is the car running rich at all? smell gas when idling? could be flooding the injectors.
Old Aug 12, 2002 | 11:08 PM
Hapa DC5's Avatar
Default Re: Help? Car bogs (NemesisGSR)
could be the ecu also check connections, ground, etc.
Old Aug 13, 2002 | 09:00 AM
Audi A4's Avatar
why would it be running rich, he didnt mention that he added for fuel tyo the set up, if anything he's be running lean b4 rich.
Old Aug 13, 2002 | 10:18 AM
jaymar88's Avatar
Default Re: Help? Car bogs (DRAG lll INTEGRA)
What is timing set at? Could be a faulty o2 sensor as well.
bobbyeg6
Feb 20, 2010 06:08 PM
vdawg559
Nov 13, 2008 03:46 AM
Jorsher
May 2, 2006 05:09 PM
djtony5
Dec 8, 2005 09:51 AM
Inspector Gadget
Sep 2, 2004 02:26 PM
