HELP!!!!
Old Aug 28, 2002 | 10:20 AM
phoju's Avatar
Default HELP!!!!
okay i bought a new thermostat and i have no idea where to look to replace it, something with hosing but thats all i know ? anyone wanna tell me where the hell it is ?
Old Aug 28, 2002 | 12:29 PM
X2BOARD's Avatar
Default Re: HELP!!!! (phoju)
1) Get a Helms factory manual... best purchase you will ever make.
2) Drain your coolant from the bottom left portion of the radiator
3) The thermostat is attached to the block on the distributor side of the motor (in the back, left when facing it)
4) You will need to detach the coolant hose (and get wet) and unbolt the 2 10mms (i think) to get the thermostat out. **An open ended wrench may work better than a socket here...
5) Remeber to replace the little o-ring type seal with a new one when you do the job.
6) re-fill coolant.
*It's a pretty tight fit in there, so you may want to remove the intake plumbing and front strut bar for more space before you start.
[Modified by X2BOARD, 4:30 PM 8/28/2002]
96Integ
Mar 29, 2009 06:11 PM
julianbc2
Dec 29, 2008 06:30 AM
RDAYA0
May 22, 2008 05:33 PM
R249
Jan 24, 2003 04:17 AM
Pat
Aug 24, 2001 09:25 PM
